spark plug? for 383LT1 DISC 10psi 8.5:1
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
so - I have a 95 LT1
the plugs I got has different length and seat taper??
Will this work??
NGK TR5 V-grooves came out with ~ .028" gap running great.
Can I stick with these for now? Will the LTCC coil conversion require a different plug than what has been running good with opti / single coil?
thanks
Will this work??
thanks
LS1TECH Sponsor
I use TR6's, you would be fine with them as well......and gap as bob said, LTCC won't change a thing with the plugs
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
The TR6 is a good plug also for lower boost. I would not use a TR5 though because it is a hotter plug.
TR5 (hotter, wouldn't use)
TR55 (stock)
TR6
BR7EF (or add S)
B8EF (or add S)
Thats all IIRC from hotter to colder. I'm using a B8EFS right now since I'm going to go to 22-25psi. Also the BR plugs don't have a projected tip. This helps with keeping the spark from blowing out under boost.
TR55 (stock)
TR6
BR7EF (or add S)
B8EF (or add S)
