Project: Stang' Bang: New Edge Turbo Build... class? Track?
#41
Thanks for the.compliment bud. Yes, I am def 100% going with the holley Hp efi.
The merge is not really a merge, lol. I utilized the twin scroll, ill get a couple close up pics after the game. And for the wastegate, I'm still not sure. Twins would be easiest, but I have a single 46 from the previous build I may try to use. Not sure yet.
#42
Spent a few hours tonight and built a down pipe, mounted up the turbo and started messing with charge pipe ideas, this is all for nothing as im switching to a truck manifold assuming i dont buck up the change for a Holley High Ram or a victor Jr. Im really really really considering it. Anyway, this is where its at right now.
Im thinking by this weekend i might have the trans back in so i can measure for the drive shaft and im able to do that, i should be able to finally get started on the inside. Id like to have the cage here within 3 weeks so i can get the seats and dash mounted. I did gut the dash, its down to nothing but a skin and a skeleton. Wiring should commence soon, boy o' boy am i thrilled about that ****.
![](http://i366.photobucket.com/albums/oo102/shafft625/Project%20Stang%20Bang/IMAG0246.jpg)
![](http://i366.photobucket.com/albums/oo102/shafft625/Project%20Stang%20Bang/IMAG0247.jpg)
![](http://i366.photobucket.com/albums/oo102/shafft625/Project%20Stang%20Bang/IMAG0245.jpg)
![](http://i366.photobucket.com/albums/oo102/shafft625/Project%20Stang%20Bang/IMAG0249.jpg)
#46
Coming along nicely. But I have one concern. It looks like you welded the braces on the cross over to the body? Is this correct? If so, how are you planning on being able to remove that crossover in the future? Am I missing something?
#49
Thank you.
Lets see, i ditched the ls1 intake and picked up a truck manifold to use instead.
Converter is back now from a pilot extension job, cross over is finish tig welded on the insides of the flange so its ready to go back on. I need to do a few small things to it, cut it and re weld it to relieve some tension thats on it, im not liking it.
Game plan for tonight is to re install trans and converter, so i can finally measure for the DS, make a mounting plate for the oil return pump, maybe get some seat position figured out, weld the torque boxes up, basically lots of house keeping and make some custom mounts for the fuel rails on the manifold.
Also scored these today![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://i366.photobucket.com/albums/oo102/shafft625/Project%20Stang%20Bang/IMAG0257.jpg)
#53
Thanks Blake! Im hoping to be driving it by the end of april ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Will do man, thanks!
West side of indy. Ill shoot you a PM.
Thanks guys!
I didnt get any work done this weekend, lol. Im waiting on my cage to get here, and still trying to decide what do about a couple of different things. However, i did get the driveshaft made and installed on Friday. So its officially connected now.
Thanks guys!
#54
Quick nothing here.
1. Cage will be here sometime next week.
2. Holley HP EFI stand alone engine management will be here either tomorrow or Monday.
3. Turbowerx EXA gear driven oil scavenge pump, only the baddest damn scavenge pump in the world will be here tomorrow as well. THANKS TOM!
4. Fuel tank and fuel system is getting the triple walbro treatment, and maybe something special......
Since we have a spare CNG kit lying around, we may try to run this thing on CNG for ***** and giggles and see what it can do. thats a big MIGHT. its been offered to me to try it if i want to. I would have to buy the tank though. We will see.
Anyhow, if im lucky, i may actually start the motor this weekend.
#56
Ok, well since im being a cheap *** this very moment, i decided id kill two birds with one stone,
I ordered a summit 15 gallon sumped tank since i could not use the stock mustang tank.
With that said, i was pretty pissed that i could not use the two walbro setup i had, especially after i just bout new line for it, submirsible, alcohol rated, fuel injection line, it was 27 bucks for one foot.
Anyway, since i did not want to waste my twin setup, and didnt want to buy a new pump, i modified what i already had, it and drilled a hole for a new bulk head fitting in the new tank. And bada bing, bada boom, twin intank walbros that lie down in the sump. can even fit the third when im ready for it.
Anyway, cheesy pics, but here they are. I pulled back the throttle on trying to get this done so quickly since im having trouble getting someone over to help with the welding of the roll cage and notching. I dont trust my self to do this.
anyway, heres a couple nothing pics.
I know said this before, but im going tomorrow to pic up the last couple sensors i need and a new battery, since the fuel system will be ran, their is no reason i cant go ahead and fire the engine up and get it through a heat cycle and re torque the heads, we will see. Ive been dealing with alot of disc issues in my lower back, so its really slowed my pace...
![](http://i366.photobucket.com/albums/oo102/shafft625/IMAG0301.jpg)
![](http://i366.photobucket.com/albums/oo102/shafft625/IMAG0302.jpg)
Oh, and a little side shot of the cobra front bumper
i love the terminator look! ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![](http://i366.photobucket.com/albums/oo102/shafft625/IMAG0286.jpg)
#58
Alright, finished the fuel cell today, and made the new supply and return lines for the fuel system all i have to do is zip them up under the car and hook them to the rails and regulator that are already in place.
Here's what i ended up with. All connections are soldered and shrink wrapped. I extended the lines up through a -8an bulkhead and 90* fitting and filled it full of "GOOP" and then shrink wrapped the end of it.
If anyone needs to know, a replacement Walbro filter sock can be had for 6 bucks at autozone, napa etc. Just ask for a 5.0 mustang, (FOX BODY) fuel pump strainer/sock and it will fit on like perfect.
![](https://i366.photobucket.com/albums/oo102/shafft625/Project%20Stang%20Bang/IMAG0312.jpg)
![](https://i366.photobucket.com/albums/oo102/shafft625/Project%20Stang%20Bang/IMAG0307.jpg)
![](https://i366.photobucket.com/albums/oo102/shafft625/Project%20Stang%20Bang/IMAG0309.jpg)
![](https://i366.photobucket.com/albums/oo102/shafft625/Project%20Stang%20Bang/IMAG0308.jpg)
![](https://i366.photobucket.com/albums/oo102/shafft625/Project%20Stang%20Bang/IMAG0313.jpg)
#59
For electrical I'm a fan of running a stud through the top of the cap/lid and double nut the Inside and outside. Then u can bolt wires on to either side without breaking the seal
But yours looks better
