Votech question
Old Mar 19, 2004 | 11:20 PM
SSC5R's Avatar
WARNING! Bad Seller Alert
Question Vortech question
Im buying a vortech system for an LS1. My question is, can I get a diff. pulley size to up the boost. I would like at least 12lbs, and is there anything else that I can get to upgrade this system. Thanks for all your help.
Old Mar 19, 2004 | 11:23 PM
MECHAM's Avatar
yes..u can pully down...u might need a 2.75 or 2.5 depending on you altitude.
the only upgrade for the system (that I know of) is a T-Trim .. and YSI - Trim. (same bracket)
www.drivefaster.net/~mecham/vehicles/ta
Old Mar 19, 2004 | 11:27 PM
SSC5R's Avatar
Thank's for the info
Old Mar 20, 2004 | 09:26 AM
30thta436's Avatar
Originally Posted by SSC5R
Im buying a vortech system for an LS1. My question is, can I get a diff. pulley size to up the boast. I would like at least 12lbs, and is there anything else that I can get to upgrade this system. Thanks for all your help.
You can pulley down and get alot of power out of that little g-trim. When you change pullies you will have to retune the computer to get the air fuel right. If you don't you will go lean and break pistons. You can go down to the 2.75" pulley with the stock vortech fuel system and tunning. You should make 550-575 RWHP. With the 2.5" pulley you will need to upgrade the fuel system. I just removed the vortech booster pump and stock pump. I installed twin walbros in the tank, with stock lines and rail. When I switched to the 2.5" pulley and tunned it, I was running out of fuel up top around 6k rpms.
Old Mar 20, 2004 | 01:04 PM
SSC5R's Avatar
Thanks for the info 30thta436 you have a mad car there. Is there a web site that has the T or ysi trim upgrade? Thanks
Old Mar 20, 2004 | 01:11 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Upgrading to a Y or YS or YSi head unit (I have YS) is essentially buying a bigger head unit. Most of those head units retail for $2500, you can't trade in your current head unit, and the bigger ones won't fit in your brackets. You can get custom brackets made but you might want to enjoy the G-trim for a while first.
Old Mar 20, 2004 | 01:42 PM
SSC5R's Avatar
Thanks Pro Stock John, would the T-trim fit my bracket? See Im trying to build this sytem right the first time. I have a 427 that it's going into, so I need a unit that wont fall on its face when Im trying to push it. The heads will be flowing 340 when there done.
Old Mar 20, 2004 | 09:38 PM
LS1Tech Co-Founder
No, A T-Trim won't just fit into the G-Trim brackets. You would need to open up your G-Trim brackets or or get custom brackets mad. Chris aka Z8's can make custom brackets by using your stock G-Trim brackets as a reference.
Now a T-Trim is good for over 800fwhp, maybe 900fwhp... not sure where it would max out.
But I'm not sure if the base aftercooler is going to support the T-Trim either.
But if i were building a 427ci and adding a blower I would definitely run at least a T-Trim, and I would get custom brackets made and then I would sell the G-Trim and the brackets together. I know that Chris (Znines@earthlink.net) has gotten a few queries for T-Trim brackets so I can maybe see him making a batch. If anyone in the Chicago area has a G-Trim car he could look at for a 1-3 hrs please let him or me know. Coopdog if you see this post HOLLA.
Old Mar 21, 2004 | 12:40 AM
SSC5R's Avatar
Thanks Pro Stock John you've been a lot of help.
Old Mar 21, 2004 | 05:46 PM
Got Me SOM's Avatar
what size is the pulley from Vortech. I thought the stock kit was good enough for 9 lbs. Am I wrong? might have to get me one of those 2.75" pulleys, anybody have a source where I can pick one up?
Old Mar 21, 2004 | 06:04 PM
Crunch's Avatar
The Vortech kit comes with a 3.125" pulley.
You can order the 2.75" directly from Vortech.
The part number is 2A038-275 $74.95
You must also buy a smaller belt. Your kit comes with part number 2A038-495 which is 49.5 inches long. You want somewhere around 48.5 inches, but Vortech doesn't sell it. Try a local parts store.
Old Mar 21, 2004 | 06:57 PM
driftpin's Avatar
BTW. Switching pulley sizes voids your blower warranty.
Old Mar 22, 2004 | 01:25 AM
SSC5R's Avatar
what's the part number for 2.5 pulley
Old Mar 22, 2004 | 11:10 PM
SSC5R's Avatar
anybody know the part # and the belt size. Thanks
Old Mar 23, 2004 | 06:32 AM
viperrt/10's Avatar
I might sell my 2.75 pulley for $50 if your interested
Old Mar 23, 2004 | 07:46 AM
Crunch's Avatar
Talk to 30thta436.
Old Mar 23, 2004 | 07:50 AM
30thta436's Avatar
Vortech doesn't sell a 2.5" pulley for it. We had it made by ASP. The belt size is 80485. I'll PM you a price on the pulley later today.
Old Mar 23, 2004 | 05:30 PM
SSC5R's Avatar
Thanks for you're help
Old Mar 23, 2004 | 11:32 PM
SSC5R's Avatar
Will the aftercooler clear taller valve covers. I would like to go with a solid roller and shaft mounted rockers.
Old Mar 24, 2004 | 05:48 PM
SSC5R's Avatar
Does anybody know
