Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
Old 04-02-2013, 05:18 PM
  #2001
87silverbullet's Avatar
Originally Posted by OldGold
What kind of shape is it in and how much? I have ported 243s, that may be too much compression with the LQ4.
Stock compression is 9.4. The 243's will bring it to 10:1 with a stock gasket. I will have to ask my business partner, the motor is actually his, but its just sitting there.
Old 04-02-2013, 10:26 PM
  #2002
Tjabo's Avatar
In the spirit of denmah, please implement option #3 and let us know how it works out. Even if you have to add a little boost to it because of loss of a little compression, this is still by FAR the best option. You'll actually be able to add a lot of boost and have way more power... What's not to like! lol
Old 04-03-2013, 12:25 AM
  #2003
HRHohio's Avatar
LOL.
Option 1: Replace broken piston with stock replacement;
Option 2: Replace all stock pistons with stock replacements;
Option 3: Replace all pistons with Wiseco JYDs in the driveway, with no balance job and no machine shop visit.
I am not getting heads milled, and blocks decked and spending a **** load of money on a $100 JY motor. I just want to put this thing back together.
Mike
If you opt for #3, you may want to pick up a $10 gram scale and check the difference in weight between old and new.
http://www.harborfreight.com/1000-gr...ale-97920.html
It may help you match up your pistons without the need for a machine shop to re balance everything. Just a thought...
Old 04-03-2013, 12:31 AM
  #2004
stangtrader's Avatar
Option 3 may end working fine if the weight is not too far off.i know people go to ls2rods and pistons on lq4 motors with out balancing all the time
Old 04-03-2013, 01:10 AM
  #2005
9 Second Truck Club
stock48's Avatar
Factory lq4 and lq9 pistons are ~470 grams. Early style rod is ~608 grams, later HD rods are ~648 grams. Usually you can go lighter on piston, and rod combo by around 30~40 grams without issue but more than 20 grams over factory can cause problems without adding to bob weight.
Old 04-03-2013, 05:22 AM
  #2006
narfdanarf's Avatar
We have gone lighter by a lot when switching to aluminum rods....stock untouched crank and making well into the four digits.
Old 04-03-2013, 08:55 AM
  #2007
Street car dude.
Aluminum rods don't work in this situation.
People have made 4 digits with untouched bottom ends.
Old 04-03-2013, 09:19 AM
  #2008
o2camaross's Avatar
How much you want for that LQ4?
Old 04-03-2013, 09:46 AM
  #2009
HRHohio's Avatar
Originally Posted by 87silverbullet
Street car dude.
I think he was just saying that going lighter isn't a bad thing... not implying that he should swap rods to Alu. That's all.
Old 04-03-2013, 05:39 PM
  #2010
OldGold's Avatar
Ok, so let's see...original rods and pistons would have been 1078 grams.
New style rods and JYD pistons would be 1090 grams.
So, that is right on the money.
Decision made! I could not find the specs on the rods and pistons, thanks!
Mike
Old 04-03-2013, 07:11 PM
  #2011
HRHohio's Avatar
Mike
Well...... That was
Old 04-03-2013, 11:06 PM
  #2012
adamantium's Avatar
Street car dude.
My buddies 9 sec street car DSM has aluminum rods
Old 04-04-2013, 09:15 AM
  #2013
1. Does he drive to work 30 miles everyday?
2. Is the motor more than a year old?
3. Does he race it more than twice a year?
4. Lets put 100k on the motor and see if they last.
5. If they're Groden's, tell you buddy good luck.
Old 04-04-2013, 07:38 PM
  #2014
narfdanarf's Avatar
completely off topic but: I wouldn't put grodens in anything, but I would have no issues putting a set of BME's in any streetcar....one of the biggest myths in the world is that aluminum rods can't be used in a street application.
and HRHOhio was right, I was not meaning by my comment that the OP should put new rods in his car...I was merely talking from a weight perspective.
Old 04-04-2013, 09:47 PM
  #2015
adamantium's Avatar
Drive it as much as he can. He drives several hours round trp to the track runs 9s and drives back him. He has a daily cause E85 isn't vastly available by him. But the cars been together for a year already, been beaten on everytime it gets taken out. Doesn't get much action cause no one wants to dig an AWD auto on the street but everytime its out its because its going out for a race or track passes or to be stepped on. The vids with the manual gear box is from a year or so ago.
The guy who put his bottom end together has a DSM that has been together for ever (2-3 years) and it runs on spray and nitrous runs 8s and its on groden aluminum rods also.... lol no need to give him good luck, it runs just fine.
Old 04-04-2013, 10:58 PM
  #2016
He must have a lucky set of Groden's then. They all spit the rod bolts out and cause all kinds of carnage.
If he can't get a race out there. Come up my way, we have good street prepped out 100 ft. No worry of the cops. Just ask Old gold how that street hooks.
Old 04-04-2013, 11:06 PM
  #2017
adamantium's Avatar
I see what your saying, i agree to a certain extent. Ive always heard this about aluminum rods but lately ive been seeing it less and less, i think it just depends on the builder. Both of these guys have had great success with groden aluminum rods.
Last i talked to him i told him to look up state Fl since it seems like more people are interested in dig racing for $. Not sure if he's interested in driving 1000+ miles for a street race though. LOL.
Old 04-05-2013, 07:03 AM
  #2018
I have been hearing its harder to get in touch with Keith (owner of Groden) and as of lately alot of guys are going to GRP, MGP, and BME rods because Groden's are failing and they are giving no warning. Guys are getting them checked and they check out ok. Put them back in the engine, 5 passes later Hope he has no such bad luck because they usually take the block with them when they let go.
That's the point though. If the price is right you will go almost anywhere. Boostedgt came down here with his mustang all the way from Dallas.
Old 04-05-2013, 09:48 AM
  #2019
OldGold's Avatar
Hey, enough highjacking!
Back to my car, which will never, ever, ever get a set of aluminum rods, LOL.
Old 04-05-2013, 10:56 AM
  #2020
Tjabo's Avatar
Did you order those Wisecos? I for one am very excited to see how that works out! I hope they have matched the "stock" bore sized pistons properly to a factory piston (a thousandth smaller or something) so that you can truly just gap rings and drop them in.
Quick Reply: Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
