Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
#2187
Wow, it's taken me two days to read most of this thread. Holy crap!! U guys are the reason we bought a $200 5.3 and are gathering parts for a build that shd start in may or June. Keep it up, it's awesome!!
#2189
UPDATE!
Made 851 RWHP yesterday on 18 psi. Still fighting issues, but we got the power to peak at 6400 and plateau, instead of falling off of a cliff. I think we may have valve spring issues, so that is next. Also picked up a Typhoon intake from a friend, so I will try that out. Alternator did its job. Slowly, I am getting there. I am still running low timing, only 13 degrees here:
#2191
What are you using to hit 850rwhp? Im doing an iron block bored to 5.7 forged pistons and rods, 317 heads, cam and higher rated springs for boost, LS9 head gaskets, ARP head studs, LS6 intake and twin 61mm turbos and font mount intercooler. I WANT to be 800+rwhp only using pump gas NO meth and im assuming 18lbs of boost. So im very interested to know your set up to hit 851rwhp
#2192
LQ4 block
Callies Compstar rods
Wiseco pistons
PRC Stage 2.5 CNC ported 243 heads
LS9 gaskets, E-Bay head studs
Lil' John's Motorsport Solutions cam, 235-237, .610 lift, 115+5
LS1 intake
80 pound injectors
12 GPH of methanol from 10 psi up
BW S480 turbo with race cover and 1.32 A/R turbine
4L80E with Circle D triple disc billet, reworked by Ultimate Converter
Custom 2.25 hotside
Custom Garrett intercooler with 5 inch core
I did this pull on 18 psi and 13* of timing. I was going to go to 20-22 psi, so I had a few gallons of FUSE 116 unleaded in the tank mixed with 93. However, I ended up not doing it. Generally, I like some race gas in there above 15 psi. However, I am very cautious.
#2194
Because until Mike can put fresh plugs in it and read them after a pull the timing will stay at 13-14*.
It's making dumb power for 18psi the way it sits right now, really no need to cram timing down its throat.
I'd rather turn up the boost and leave the timing low. Timing is what wrecks engines. I like managing the cylinder pressure the engine is making by running low timing and running a lot of boost.
#2195
It's making dump power for 18psi the way it sits right now, really no need to cram timing down its throat.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
It is no slouch for sure, not denying that, I just think its going to need timing sooner than later.
#2196
In my experience, every time I push the timing something breaks. So, I will keep it conservative and alive.
Mike
#2198
Mike
#2200
What plugs are you running on this setup?
Congratulations on your progress. Outstanding... And "Conservative and alive" is a good thing. More time racing... less time wrenching.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
