Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
Old 09-09-2012, 03:03 PM
  #801
Moderator
denmah's Avatar
too scary for island dragway
Old 09-09-2012, 03:04 PM
  #802
Moderator
denmah's Avatar
Originally Posted by adamantium
So it picked up MPH correct? Without nitrous?
yeah nearly 2mph without nitrous and worse air conditions and a worse 60ft lol
Old 09-09-2012, 03:10 PM
  #803
BottleFedZ346's Avatar
Not to shabby mph wise in the 1/8th, are you still not running a bov?
Old 09-09-2012, 03:12 PM
  #804
Tuckin15s's Avatar
Did you lower it at all? being ride height
Old 09-09-2012, 03:45 PM
  #805
Moderator
denmah's Avatar
Still no blow off, it's stock 4 cyl suspension that's why it's lower now with the 5.3 and 80e
Old 09-09-2012, 04:30 PM
  #806
Tuckin15s's Avatar
That's what i thought but it has great stance!
Old 09-09-2012, 04:36 PM
  #807
adamantium's Avatar
LOL **** dyno #s. Perfect example of that. Congrats man! Still throwing the heads on there?
Old 09-09-2012, 05:50 PM
  #808
Moderator
denmah's Avatar
haha yes everyone said it sits perfect
Old 09-09-2012, 05:51 PM
  #809
Moderator
denmah's Avatar
http://www.youtube.com/watch?v=jFsio...ature=youtu.be
Old 09-09-2012, 06:18 PM
  #810
lsxmalibu's Avatar
try better heads...whats your car weigh, mine did 106mph in the 1/8 on 10 psi, with the ls6 cam. with the 799 heads.
Old 09-09-2012, 06:20 PM
  #811
Moderator
denmah's Avatar
yeah i am gunna get a set of 317s from a friend and give them a try.
my compression is only 130psi closed throttle so its gotta be a fairly low compression 5.3 haha
Old 09-09-2012, 07:56 PM
  #812
S1LV3R's Avatar
So they ran you off because your car COULD go too fast. Not because you went too fast?
What did it run in the 1.8th?
Old 09-09-2012, 08:02 PM
  #813
Boosted Firehawk's Avatar
you will have like 8.8 compression with 317s...very weak to my understanding
Old 09-09-2012, 08:44 PM
  #814
j88l98irocz's Avatar
im gunna throw on 317 heads from a friend, and probably do a compression check on all cyls just for fun. car went 107.8 mph in the 8th today on a 2.0 60ft
Iron 317's
Old 09-09-2012, 08:56 PM
  #815
S1LV3R's Avatar
Here's an S-10 truck with 5.3 and 317's
Old 09-09-2012, 09:13 PM
  #816
a4ls2goat's Avatar
was this on a cold motor?
Old 09-09-2012, 09:34 PM
  #817
Moderator
denmah's Avatar
yeah i believe so
Old 09-09-2012, 09:42 PM
  #818
a4ls2goat's Avatar
so itll be about 150psi warm. which is not bad for a high mileage motor.
you should be trapping about 136-137mph in the 1/4 how it sits, which is not bad
Old 09-10-2012, 01:27 AM
  #819
Moderator
denmah's Avatar
yeah that is great considering the 4.8 was 22lbs and 125shot to trap 138
  #820
Moderator
denmah's Avatar
i know with a little more boost it might even go 140 boost only.
Quick Reply: Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
