Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
Old 09-12-2012, 02:33 PM
  #841
Moderator
denmah's Avatar
damn 128mph sick!
Old 09-12-2012, 11:30 PM
  #842
skinnies's Avatar
http://www.usplastic.com/catalog/ite...lickid=popcorn
Old 09-13-2012, 12:26 AM
  #843
55superbeetle's Avatar
Help me out here, are you just replacing the stock check valve with this because the stock one isn't up to the task with boost knocking on the other side?
Old 09-13-2012, 02:47 AM
  #844
skinnies's Avatar
In my case the stock one wouldn't hold up to boost, it did for awhile then failed. The replacement one failed almost immediately, so running ONE of these inline. We tried running 2(incase one failed), but it was too much of a restriction so ended up going with one.
Old 09-13-2012, 08:44 AM
  #845
Moderator
denmah's Avatar
thanks dude...
im a street car
Old 09-13-2012, 08:50 AM
  #846
a4ls2goat's Avatar
Because race car.
Old 09-13-2012, 11:42 PM
  #847
TURBO8's Avatar
Wow! Just read the whole thread. Amazing! I loved how you broke the ring landings, and bent the rod o one piston and just threw another in and kept on boosting. I love it. I always thought if I blew the motor, id s just replace it with another $400-$800 motor. I was shocked to read that you where finding these motors for $80. Amazing!
Old 09-13-2012, 11:49 PM
  #848
TURBO8's Avatar
What gears did you have in the Silverado with the 4l80e, gt45, and all?
Old 09-14-2012, 02:56 AM
  #849
95bowtie's Avatar
Have you set ur tru boost to hold wide open letting pressure from the comp. Go to the top of the gate? It will let you do that to whatever pressure you set it to.
It says to set it 2# lower than what your wastegate cracks at. Mine has a 7# spring but only makes a steady 5# on spring only. I set mine to over what the wastegate spring cracks at anyway to try to build boost quicker on my rear mount.
Old 09-14-2012, 02:58 AM
  #850
95bowtie's Avatar
I think I'd you did it my way on the front mount you would get boost spikes possibly tho so maybe just test it out
Old 09-14-2012, 06:43 AM
  #851
Moderator
denmah's Avatar
4.10 gears.
30 inch drag radial
Old 09-14-2012, 08:28 AM
  #852
Moderator
denmah's Avatar
yeah i know what you mean, ill probably try leaning it out and throwing in some more timing at thresh hold since that seems to work great for other people.
my car is in the high 11s trying to foot brake it, so that is killing it a bit, ill try leaning it out to like 13.0 on the foot brake while trying to build boost and see if it comes up. the brakes are getting better everyday there was definately some **** in there ive knocked loose, i bled em again and they are really getting there.
other than that ill be taking it to the grove tonight and holding it at like 2500 and dropping a 100 shot on it to 60ft it and ill probably leave that on the whole way down the track, trying to bomb a 9 second pass and drive home was my goal for the car since i started.
Old 09-14-2012, 08:51 AM
  #853
RedRocketZ28's Avatar
Good luck tonight man. Can't wait to see the video.
Old 09-14-2012, 09:00 AM
  #854
Moderator
denmah's Avatar
toasty fireballs
Old 09-14-2012, 09:05 AM
  #855
Moderator
denmah's Avatar
a friend of mine just texted me and said they are closed tonight, so ill probably call and check, but they are supposed to be open at 9am tomorrow morning...
Old 09-14-2012, 09:09 AM
  #856
a4ls2goat's Avatar
Good luck man.
Old 09-14-2012, 12:17 PM
  #857
SSZ
SSZ's Avatar
Denmah, you going to the nhra event at maple grove in a couple weeks?
Old 09-14-2012, 08:05 PM
  #858
86lxnotch's Avatar
cecil! im taking a customer's car there tomorrow for some shakedown runs on his car. we just hooked up the nitrous for him
Old 09-14-2012, 10:35 PM
  #859
Moderator
denmah's Avatar
Best et 10.17 best mph today 141... So close
Old 09-15-2012, 12:06 AM
  #860
Moderator
denmah's Avatar
Quick Reply: Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
