Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
#1382
What part are you not understanding Pontiacpowa. Thats the custome F N Monster *** Cam that was in my POS ford 418 stroker. Matts cam isnt as big as his Noas Ark 4L80E. I love his video comentary freaking funny as hell The Misadventures of the Shoeless Racer...
#1384
Denmah Just gapped my rings to the width of the Grand Canyon but cant find the rod torque specs. which im sure you followed to the T... any idea on something other then T I T tite?
#1385
http://www.ls1howto.com/index.php?category=1
gen 3 15ft/lbs plus 60 degrees
gen 4 15ft/lbs plus 75 degrees
ARP..follow the directions supplied lol
#1388
GM has introduced a new connecting rod bolt torque specification for GEN III and GEN IV Vortec small block V8 engines. The new specifiation continues the use of two passes. The second pass value has been increased from 75 degrees to 85 degrees.
Tighten the connecting rod bolts a first pass to 20 N.m (15 lb ft).
Tighten the connecting rod bolts a final pass to 85 degrees using the J 45059 Angle Meter.
http://www.enginebuildermag.com/Cont...0000029225.pdf
Not sure if you guys have seen this, for what it's worth.
#1390
i absolutely reused the connecting rod bolts.
cars been running great, had it out for a long time again today with the microsquirt on 21lbs of boost.
ended up removing the ms1 and MSD box for now and permanently wiring in the microsquirt, and hooking up the tach output and some other things, cleaned up my wiring. i dont think im gunna have anymore problems with it, and at this point i think i have decided ill work through them...
car is doing great, "new" motor has been excellent. going to get it on the dyno friday at the latest.
#1398
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
SO the heads are torqued down to impact torque no sequence in torqueing order???? Stock head gaskets??? WOW great job dude i'm impressed how fast you get you **** done.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#1399
studs are 40 then 80ftlbs on a middle working out pattern no particular order.
then i did the 15ftlbs and almost 1/4 turn eyeball on the stock rod bolts
everything is stock-reused, everything else is hammered down with a cordless rattle gun or a 6 inch ratchet.
right now its a 03 block 08 flat top gen4 pistons and rods
ls1 head gaskets re-used, g8 manifolds, LS1 intake, truck throttle body
