F1A-390ci-E85
i have said it before and i will say it again, youd be nuts to buy the ATI FMIC by itself. If you get it with the kit, its basically a 200 dollar add on instead of a 1400 dollar add on. that is the only reason I have it. I have heard of the same thing happening with some higher end radiators and ****.
Hows your build going man? You and your dad took that hit a while back due to ole ******** Mcgee, but I am hoping your moving on to bigger and better things now.
well good to hear you didnt quit man.
I got the ABS out since were deleting it anyways.
got the ridiculous *** wire harness out and wrapped up.
found out (finally) how you get the heater core away from the firewall.
got the rest of the a/c **** out.
there is nothing in there now, and its clean as a pin and scuffed.
next week the body shop guy is going to load it up, and give me a deal for doing most of the prep and removing everything. real class act kinda guy for doing this for me. Another place quoted me $2000 another quoted me $1600
I was like.......the ******* motor and all that is OUT! ......but leave it to another F body owner to pick up the slack and cut through the bullshit to help someone out.
It is going to look great. BlackWS666 is the reason I decided to go ahead and get it done. It should look similar to the one in the pic below.
I just finished primering my engine bay Friday. I hope to have the firewall and all the way up to the strut towers painted this weekend. I am going to leave the rest primered until I get the turbo kit mocked up and see what all I have to cut,weld or modify.
Thanks man. Post pics of your bay when your done. Would love to see how it all turns out. Appreciate the compliments.
In the meantime I got my Trans Cooler, My -6AN fittings, SSB lines for the cooler, and My Dipstick, Madman HVAC delete plate, and a nice new puke tank from Jegs.
Lost my Cam so best I can do is webcam photos.
Go pro Hero 2 is in my future tho.
I just need to grab some black lines to run off the valvcovers from Russels Fittings and get this plate and can painted. I am going to mount the can under the car somewhere easy to get to.
SJM linelock & ABS delete is on the way, and a switch for the trans brake. I really think I would personally like to have it on the stock shifter.
I am looking into some Cobra seats once I figure out what the weight and prices are. Light, comfy, good looking seats man.
I chose Comp Cams break in oil. and K&N oil filters and as stated before I will switch to a fully snthetic VR1 racing oil. 20w/50 from there on out.
The car is out of the paint shop from having the engine bay done and it looks great.
Assembly is starting this week, 160* thermostat is on the way, and I will be using custom made fuel pumps from lonnies that are true 340 pumps. So should be the equivalent of a 680lph setup. or 180 gallons per hour or 3 gallons a minute. I wanted to go Magnafuel, but the rise in fuel temps and the noise is something I would like to avoid to make the car that much nicer.
Now all we have to do is hope the ring gear/pinion, and driveshaft are up for the dyno challenge ahead. Should get interesting here really soon.
Im sure you all saw the e85 364ci c6 make 915 through a 6 speed recently so I am going to make my guess and say 865rwhp through the stalled auto once shes dialed in right.
I plan on having her ready to hit the track hard around the beginning of fall. A full suspension setup is all that is needed along with a little weight loss, which I am already doing in small stages now. My goal is 3350 and I only weight 140 so that should help get me some decent 60's along with Eric's help @ MWC. He said hed make it happen and I believe him.
When I get ready to run I am going to rent a track elsewhere so that I can find out what the car likes as far as the DA AFCO settings and getting my 60 foot down as low as I can. My tuner will be with me keeping an eye on the logs and making small adjustments.
I may add in a two step, but I am undecided. I am really just wanting some seat time with no one beside me so I can get used to driving it on two wheels. I am not nervous, I just think to be safe for the person I am racing it is best to have some 1 on 1 with the car before I start frequenting local tracks.
