F1A-390ci-E85
Old Feb 2, 2013 | 11:35 AM
  #161
I8UR4RD's Avatar
Originally Posted by blue00ZZleeper
Let me know about the fuel system. I'll be home next week so whenever you want it, let me know.
glad your coming home dude. Its time for you to get back in the game. I will pay get you the money by the 5th of march.
Old Feb 7, 2013 | 07:15 PM
  #162
I8UR4RD's Avatar
Stg 5 80e----currently being assembled and should be on its way soon. Its a late core, and has a bigass trans cooler, fittings, and lines coming with it. Comes in black too
The Dual Valvesprings have shipped. PRC .675
The 60-80e swap harness is on its way from frost.
The K member is taking a good bit longer than I anticipated, but is being powder coated and ships early on mon-tues.
Got my cutout on the way too! 3 inch qtp with wireless remote controller.
Other than fuel and suspension and tune, I am ready.
And I am runnin the spal extreme 16'' with no condensor to worry about it should do good. Almost flows 3000cfm
just watching the clock at this point.
Old Feb 8, 2013 | 09:41 AM
  #163
EDISKRAD EHT's Avatar
Subbed for results. I quite enjoy my AES 385, and F1A setup.
Old Feb 9, 2013 | 01:50 PM
  #164
I8UR4RD's Avatar
Appreciate is bud. Glad your happy with the setup.
Old Feb 9, 2013 | 02:23 PM
  #165
allout06's Avatar
Looking forward to the ride i get when your up this way. Get on it!
Old Feb 13, 2013 | 01:24 PM
  #166
I8UR4RD's Avatar
Got the 80e swap harness in. Neatly packaged, and with instructions. Frost went out of his way to take care of a shipping issue for me that was in no way his fault, and turned out not to be an issue at all.
Talked with Jake and his wife the other day. He had the trans on the table assembling away. Decided not to rush him, and told him to take his sweet *** happy time. Good work is slow/steady work in most cases.
The Spal Extreme is in. I touched the blade and it sliced my finger up pretty good. Spal says its not for street use. We will see about that. 10,000 hour lifespan on the motor. And not to run it for more than 30 minutes per there own Tech support. The motor on them is apparently not sealed. Allows them to spin harder or something/cool down.
Also, I finally got my MWC K member in. I saved some dough and got the mild steel. It was only a 2lb difference from the CM, and Eric said that for cars that are on the street a good bit, that it would be better in the long haul. Great welds, and came in at 20lbs.
I just need to find out where I personally need to place the trans brake button. Been considering the window switch panel or near the traction control button, or just use the traction control button possibly.
Not sure if I will run the cutout right after one of the headers, or in the I pipe. I pipe sounds easier. and that would be a 3 inch exhaust setup up till that point.
Old Feb 13, 2013 | 02:32 PM
  #167
The Alchemist's Avatar
UNDER PRESSURE MOD
Nice progress.
Old Feb 13, 2013 | 05:16 PM
  #168
35thsscamaro02's Avatar
I'm really loving your build! Wish I could swing it but I have wife a kid and another on the way lol . Goal for this year is to slowly accumulate parts. I will have some good updates soon. I have the 3.4 pulley on and it screams :-) stock block FTW
Old Feb 13, 2013 | 11:03 PM
  #169
I8UR4RD's Avatar
your build is the one to be admired. yours is what I was originally after. A stock bottom end with a maxed out D1 that just wont die. I wanted to beat the **** out of the stock motor. Give me time to buy the new one and have it on standby.
Your car is badass dude and its amazing what it puts up with. RPM/ Frans96ss has a red corvette that makes over 700rwhp and has for over 10k miles and will not blow up and gets beat on all the time. From the best I can tell from examining all the data, and talking with alot of people about the problems I was having before I put it on the dyno, was that the head was lifting slightly above 6400-6550 rpm and spraying coolant. I could not figure out what was going on when that happened. It would leak on the driveway, but never stain. At the time I just swapped the pinion seal, and the valve cover gaskets, and it would stop(i thought) But 160+ mph runs took there toll, and it was ready to go when we put the mojo to it. I cant believe it was making that much boost with a 4.13 pulley at that rpm. I am guessing it would have made 15-17lbs all told. I think a good head gasket swap, and some studs are in order for anyone looking to procharge a stock motor, especially that is going on 10-13 years old. haha.
I ran that car hard as hell. At the strip every weekend. Dyno tuning, huge burnouts,cannoball runs. I doubt I will be as careless with it now. 400rwhp does not demand quite as much respect as 8-9.
I went over the logs and the AFR was 11.2 and looked like this _______________________________________________ through out the run. The timing was 17 degrees and the methanol came on at 4 lbs and was set to level 8. 100% duty cycle in around 8-9. I had 93 shell, and air inlet temps were great.
Old Feb 15, 2013 | 03:29 PM
  #170
I8UR4RD's Avatar
Got my wireless cutout setup today. Going to be shweeeeeeeeeet.
Lock the car.
Wait for someone to walk by, and look/stare/listen.
Open the cutout, from nearby.
Plus from my experience a cutout makes a car sound lopey even when the cam doesn't have the LSA for it.
Old Feb 15, 2013 | 03:42 PM
  #171
allout06's Avatar
itll b lopey if you have the exhaust duration and lift for it . u can always hear a cam better with no muffler, or exhaust tubing to deaden the sound. its gonna sound bad *** dude. im contemplating on buying dual cut outs for each of my down pipes and dump them by the front fenders. >
how much were the wireless ones?
Old Feb 15, 2013 | 03:45 PM
  #172
allout06's Avatar
nvm, found em both for $340, electric cutouts.
Old Feb 15, 2013 | 06:25 PM
  #173
I8UR4RD's Avatar
I found em for 300 a piece. the remotes were a 70 dollar option.
Old Feb 15, 2013 | 06:35 PM
  #174
allout06's Avatar
The ones i found r just the solenoids. Ill make my own pipes.
Old Feb 25, 2013 | 03:58 PM
  #175
I8UR4RD's Avatar
Trans shipped today! got my tracking number and could not be happier with the serivce. Lots of communication and patience in dealing with me from Jakes Performance. I am pretty picky, and bad about changing things at the last minute as a result of constant research of other setups.
I am not going to post again until we begin assembling.
Old Feb 26, 2013 | 07:29 PM
  #176
I8UR4RD's Avatar
Jakes Performance Stage 5 with the new D3 transbrake. New style core, with the fittings already on it. Heavy ****. jesus.
Old Feb 26, 2013 | 08:05 PM
  #177
craig382ci's Avatar
What size intercooler is that and brand?
Old Feb 26, 2013 | 09:27 PM
  #178
I8UR4RD's Avatar
It is the ATI race 1300hp FMIC
27.5 x 12 x 4.5 W/H/D
3.5 tube diameter.
Its a pretty big piece. they are pretty expensive, but when you get it with the kit its more of a bargain. I have seen some of them hold back alot of flow from the blower, and people having issues getting PC to acknowledge that and swap them to a vertical one. Some have had boost leaks at the welds, but I have seen similar issues with Cx and others. I will be measuring before and after the IC to see how much I lose.
Old Feb 26, 2013 | 10:15 PM
  #179
craig382ci's Avatar
3.5 tube diameter.
Are they room for a bigger one? If so please give the measurements.
Old Feb 26, 2013 | 10:36 PM
  #180
I8UR4RD's Avatar
I think the other one that bob was using back @ EPP was a 31x12x4 from Cx racing. about the same size id guess and definitely cheaper.
