F1A-390ci-E85
Old Dec 17, 2013 | 03:09 PM
  #401
allout06's Avatar
Well just found out the motor was never been cranked after the new cam install. Has to be engine builder error.
Old Dec 18, 2013 | 07:44 AM
  #402
I8UR4RD's Avatar
yeah after i tried to crank it months ago and it wouldnt i just gave up.
so when i decided to change cams, and the cover was pulled, i was sent photos. The thing was not lined up. New cam installed, and everything lined up right now.
Old Dec 18, 2013 | 08:16 AM
  #403
The Alchemist's Avatar
UNDER PRESSURE MOD
That sucks... Hopefully nothing was hurt and things move smoothly from here.
Old Dec 23, 2013 | 06:21 AM
  #404
James@ShorTuning's Avatar
It was also giving us a crank/cam variation code which indicates the cam was off prior to Jared opening the engine up to swap the cam. I personally cranked on it for a bit after I flashed a base tune to the car and it didn't act right at all. Never fired up. What we think happened is they installed the cam dot down with the cranks dot down instead of up.
Old Dec 23, 2013 | 07:16 AM
  #405
Cam72aro's Avatar
Who installed the cam? A 3 year old? Definitely sucks. Hope it gets together and you have no more problems.
Old Dec 23, 2013 | 09:51 AM
  #406
UNDER PRESSURE MOD
That's why they say DOT-to-DOT, the two should be next to each other, not 180* from each other.
That sucks.
Old Dec 23, 2013 | 02:14 PM
  #407
That sucks.
Correct, dot to dot isn't a hard concept to remember haha. I'm trying to figure out how anyone "degree'd" the cam in with it being off like this. When I tell someone I've degree'd their cam in that means I have used a dial indicator to find TDC located on a degree wheel mounted to the crank and then ran through the entire engine cycle with a dial indicator on a lifter to indicate all the specific valve events for both intake and exhaust.
Old Dec 28, 2013 | 09:54 AM
  #408
I8UR4RD's Avatar
Compression got raised to 10:1. Heads are done being milled already and on there way to being put back on. Should bump up power somewhat. I think all the problems have been solved now and we can try to get this thing thumping finally. Dammit I'm ready lol.
Old Dec 30, 2013 | 12:43 PM
  #409
I8UR4RD's Avatar
Heads back on. Tried to start up. Won't start. Going to look into the tune a bit, but if that's not the case thinking the reluctor wheel is not right.
Issues I've had so far.
Gen 4 block sent instead of gen 3.----means $500 for ls2 swap kit. (new sensors harnesses)
Not timed correctly aka bent valves. (builds top fuel motors)
Compression not what I asked for originally. Had to mill. (customer should get exactly what they want for 9 grand)
Possible that reluctor wheel is not right. (lets play the blame game. callies? aes?)
Sigh :/
Old Dec 30, 2013 | 01:30 PM
  #410
UNDER PRESSURE MOD
That really sucks. I understand issues happen, but that's crappy quality control right there. It sucks that you have to go back and double check something that you paid to have done right.
Old Dec 30, 2013 | 05:38 PM
  #411
I8UR4RD's Avatar
We will see....If that is the case it will mean a complete teardown
Old Dec 30, 2013 | 05:49 PM
  #412
allout06's Avatar
if the reluctor wheel is off. id have them reimburse you for the ******* shop time its gonna cost you to pull the motor, strip it down, ship it, and put the ******* thing back in. not to mention the cam wasnt timed right costing you money in valves and milling the heads. hell. mine may have been timed wrong, i just happened to swap cams before i fired it for the first time.
Old Dec 30, 2013 | 07:06 PM
  #413
Cam72aro's Avatar
They better make it right is all I have to say, if it's their fault.
Old Dec 31, 2013 | 02:57 PM
  #414
conan's Avatar
Wow man hope you get to the bottom of all this with out too many more headaches... Good luck.
Old Dec 31, 2013 | 06:16 PM
  #415
WS6 SRT-8's Avatar
And I thought I had bad luck! I hope you get it straightened out.
Old Dec 31, 2013 | 06:36 PM
  #416
Tirefire's Avatar
Compression test on my block was low in two of the cylinders? All were in the 225's except two, #1 was at 210 and #6 was at 200. Called AES they said it was because the motor had not been broken in yet. Car runs strong and I havent checked compression again since. When I called them they had no idea who I was they said they had just gone to saving all their info into to a server. My block was number #51, they had no clue, weird. Just my two cents.
Old Jan 1, 2014 | 12:53 PM
  #417
I8UR4RD's Avatar
this is the only thing I've had a problem with. Jakes performance brute speed Texas speed circle d and loNnies and hell....even FIC have all had flawless complete and professional products they stand behind. I feel like my **** was thrown together at a whim and just disregarded because it's not a 60k dollar big block going on a car to win some race In australia. I've talked with alot of folks and despite the fact that I don't know everything there is to know about building a race engine I do have heavy influence.
Old Jan 1, 2014 | 01:14 PM
  #418
jjcamaro02's Avatar
Joey that sucks! I hope it's just something simple.
Old Jan 1, 2014 | 01:24 PM
  #419
I8UR4RD's Avatar
Well I haven't made a phone call about the other issues yet. But once we get some hard evidence I'll feel justified. The main thing is time. I'm growing impatient. I think I've neared my limit. I have wicked thoughts of selling it and doing a H/C c7 lol. without the support from you guys and people like shortuning and race proven performance Id've probably abandoned ship by now. Life was simple when she was cam only.
Old Jan 1, 2014 | 02:10 PM
  #420
jjcamaro02's Avatar
Hang in there you have put in a lot of time and money to just give up. When it's all said and done it will have been worth it. I know what you mean about life being simple but if it were easy any body could do it.
