One Guy's Garage 71 Nova TT 5.3, The Quest for 7's.
#222
Funny you say that. Im considering putting one on FOR an autox event. We have an autox here that turns right into a 1/3 mile top speed run. Mostly imports that go 110. This year my friend and I show up and he smokes the 142mph record held by an Evo with a 156mph run in his TT GTO. He has 14" brakes. The shutdown is rediculously short with a creek bed ravine at the end. I went 142 and wussed out shutting down early. Since the car goes 150 in the 1/4 now Im pretty confident it would go 155 or more so but sure as heck not doing it without a chute.
#223
#234
I read that you used the corvette pump/alt bracket. Did you have to change the pulley or anything else to use this setup?
#238
Before you mod the manifold, put the bracket, pump and pulley on the engine. The angle off the manifold needs to be pretty steep. I trimmed the bracket with a die grinder to add clearance, the steel LS 2 pulley is slightly smaller than the C5 pulley. And it's spoked so you can get at the bolts for the pump.
I started with a C5 ps/alt bracket but switched to the Holley bracket when I realized the Camaro alt doesn't fit the corvette bracket. I have the complete corvette bracket setup left over by the way.
This shows it pretty well.
About 1/2" clearance to the pulley.
Ron
#240
Im pretty pumped about taking 100lbs off the front of the car with this build. The SC&C front suspension kit kicks *** and the car handles really well, even with 235's. I'll prob switch to 9" wide front wheels and 275's next year.[/QUOTE]
Can you give a link to your front suspension parts like A-frame, and front springs.
