-12an oil drain flange...where to buy???
what do you mean flange? the turbo or the pain. i bought a think a 1/2 flange and put a 1/2" to 12an fitting and then ran a 12 an line to the pan. then for the pan i bought a weld on 12an flange and drilled and welded it
i just checked on the bay and 9.99 for a flange and 7.99 for a 1/2 npt to 12an adaptor and those are just the cheap ones. nothing fancy. and since its just a drain portion, cheap aint bad. i went with a 10an for mine. my flange comes with 10an on it already so i didnt have to find an adaptor but these are easy and cheap. but im sure any of the vendors here dealing with fittings will definiatly have something your looking for.
The t76 is a fairly large midframe isnt it? i know its not a huge 100mm or anything but 76mm turbo is fairly large. in the desription it says it fits most midframs. i dont have one so i cant say for sure. just trying to help where i can
Just to clarify since this post comes up on searches, the Precision T76 is a small frame turbo. I was hoping to buy the Wolfe piece, but that's a no-go. ![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
