WS6 S475 official build thread.......
Old May 13, 2013 | 07:01 PM
  #281
Sales@Tick's Avatar
Get the blanket and turn the fans on sooner.
Old May 15, 2013 | 07:16 PM
  #282
mrstepheneades's Avatar
Blanket ordered today
Old May 21, 2013 | 07:46 AM
  #283
Here are some pictures of my new turbo blanket. Hopefully will help a lot with the heat under the hood.
Old May 21, 2013 | 05:42 PM
  #284
Sales@Tick's Avatar
Looks great!
Old May 21, 2013 | 06:03 PM
  #285
Ryans99ls1's Avatar
stock fans arent the best pushers. I still have the stock radiator with a 160deg tstat but i have 2 derale pushers. they keep it plenty cool on 90+deg days in traffic. My fans stay on for 3min after i shut it off and the coolant temp is above 185
Old May 21, 2013 | 09:43 PM
  #286
If the fans are staying on 3min after you cut car off doesn't that mean its to hot. Mine don't stay on anymore since I took thermostat out. Mine will get to 215 in traffic and back in 190s on highway but not tested it since I added blanket.
Old May 25, 2013 | 02:29 PM
  #287
Ryans99ls1's Avatar
We tuned it to stay on for 3 min if the coolant temp is over 185. it only gets that hot if im in traffic, otherwise she stays cool.
Old May 25, 2013 | 09:49 PM
  #288
Oh OK. Yeah mine stays below 200 all the time now that I got turbo blanket. It really helped.
Old May 26, 2013 | 09:44 PM
  #289
Little acceleration video for you guys.....
Old May 27, 2013 | 07:52 AM
  #290
Camaro9969's Avatar
Sounds good man I'm sure the 6 speed is a lot of fun!!
Old May 27, 2013 | 08:35 AM
  #291
Oh yeah. Love bangin gears.
Old May 29, 2013 | 03:27 PM
  #292
Put the stiffer spring in. We could only get 4-5psi out of the spring that came in my JGS. Pulled it out and put the stiffest one in the box in it and it made 9.5lbs on the spring alone. My little Hallman manual controller holds it 15-16psi now.
Screens are much worse than filters, they really mess the incoming flow up. Get a filter with an inverted cone at the end, TONS of cheap ones out there.
I would have been surprised if you got off the dyno scott free! we had mine on there for 8+ plus hours chasing issues that couldnt be seen until we were ready to tune.. Youll get used to the power FAST, turn it up!
So in theory, I need to leave the spring that come in the jgs gate in there (4-5psi) plus add the stiffest one (9.5psi). And stacking these should yield around 14psi??
Old May 29, 2013 | 06:22 PM
  #293
Sales@Tick's Avatar
That thing sure gets up and goes for 500rwhp!!! Where are you seeing full boost rpm wise Stephen? Looks like that Stage 3 Monster is holding up well!
Old May 29, 2013 | 08:28 PM
  #294
Full boost 4000-4200 rpm. Makes 5 psi around 3500rpm though. Feels like its kicked in the *** those last three pounds though. Holds good traction if I lazy shift. But if I speed shift like I use to with my na car its like its on ice lol.
Old May 29, 2013 | 09:59 PM
  #295
Sales@Tick's Avatar
That's awesome. Proper cam timing can really help spool as seen in your case. If you were to ask guys on this form where they thought you'd be making peak boost by or where you were seeing 5 psi they'd never say at that low of an rpm with such a large turbine and housing.
Old May 30, 2013 | 06:34 AM
  #296
Ha I can load it at like 2000 rpm and make a few psi enough to get that nasty whistle coming out the dp and ehcoing off the buildings down town. Its a head turner lol.
Old May 30, 2013 | 07:39 AM
  #297
BOBS99SS's Avatar
Captain Double Post
Thats the baddest sound,good work looks like a real fun car
Old May 30, 2013 | 07:57 AM
  #298
The clutch holds good Martin. No slipping whatsoever. Little jumpy in traffic and backing up but thats to be expected.
Thanks man.
Old May 30, 2013 | 10:37 AM
  #299
Sales@Tick's Avatar
That's freaking awesome Stephen. Now turn that thing up!!!!!!!!! Also, I should of had my head pulled out of my *** when I told you about the methanol nozzle placement, I didn't realize your BOV was going to be after the nozzles instead of before. I would move the nozzles to after the BOV so that when you do turn it on, and you lift off the throttle and the BOV relieves pressure that you don't send a shower of methanol onto your hot side.
That would be bad....
Old May 30, 2013 | 10:47 AM
  #300
lol that would make since. I will see if i have any room. How far do the nozzles need to be after it?? 4-5"???
