WS6 S475 official build thread.......
So last night i just took the thermostat out. Engine was cold so i cranked back up and let it run till fans come on. Usually it would only take 4 to 5 min for fans to come on but this time it took like 15 so i know its running way cooler at first. Then i took it up the road and run hard through the gears over and over and over just right near my house. Even boosted it hard before i pulled in driveway. When i turned car off, no fans running so i believe its running way cooler now.
The gauge in these cars sucks. It says im running 210 4 minutes after start up regardless. Im gonna drive the car back to work on my lunch break after it warms up today and hook scan tool to it and see what the pcm is saying the ect truly is. That way i will know what temp is getting to after a hard pull and if it cools back down.
Anyone have similar issues??? Or input on this matter?
My ECT's climb after doing pulls and that is to be expected. I have 3 holes drilled in the thermostat also. FWIW, my fans are programmed to run for 90 seconds after the car shuts off.
IAT's stay around 73 degrees driving and boosting on a 70 degree day even with no wrapping pipes underhood so intercooler is definitly doing its job.
