stock LY6 longblock mild build, re-gap rings and head studs or leave alone?
i have a 2009 LY6 with 60k miles on it. building a mild turbo setup for it and am curious if i should bother taking the heads off, gapping the rings and doing head studs.
i will only be running 8-10lbs of boost. it has a LS3 intake and will get a custom cam. turbo is a s475, normal stuff. just shooting for 550-600hp on pump gas.
so leave it alone, or break it down?
thanks
mike
thanks
mike
I always do rod bolts and re-gap. But if I was going to do only one, the re-gapping is needed first. Its needed less on a high mile engine, but on low miles I've seen what happens when you dont re-gap first hand. (ring land popped and also cracked the cylinder wall too
Good luck.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Good luck.
ive ran about 18psi on my 2008 4.8 with about 10k miles on the motor. the motor is pretty much new. no problems here. i left everything alone on the motor. just changed the valve springs/pushrods/cam and gave it hell, this is on e85 though. keep the timing low and itll live.
IMO As was mentioned I do not mess with the ring gap on high mileage engines. I would at the very least pull one piston and check the gap. If it was less than .024 I would re gap to .028. If it is already .022 I would just leave them alone and throw on a set of LS9 gaskets and be done with it. At the very least I would check one though.
