fairmont 3.0 (5.3, isky 3x12, s476r) 721rwhp @ 17psi pumpgas 9.68@145mph
Old 10-29-2013, 09:36 PM
  #341
Moderator
denmah's Avatar
Old 10-29-2013, 09:40 PM
  #342
HRD
HRD's Avatar
"Im giving hot rodding back to the people! SloppyMechanics WIKI"
Love it!!
Old 10-31-2013, 08:50 AM
  #343
douglee25's Avatar
Like the pic!
Doug
Old 10-31-2013, 07:45 PM
  #344
Moderator
denmah's Avatar
https://www.youtube.com/watch?v=-3lv...ature=youtu.be
Old 10-31-2013, 09:36 PM
  #345
merim123's Avatar
sounds nice. curious to see this powerband when you get it on the dyno and at the track how much you'll pick up
Old 10-31-2013, 11:46 PM
  #346
Tanus's Avatar
So you have ran gt45, on3 76 and twin 57s.
Which would you think would be best for a pretty much stock 5.3? Just studs, gapped rings and springs with a small cam, not sure which, whatever I find cheap. Oh also everyday street use.
Old 11-01-2013, 11:45 AM
  #347
Moderator
denmah's Avatar
i like the on3 76 so far because it is half the size of the gt45 and seems to make the same power
twins are more expensive. so i would say dont do that unless you want to.
Old 11-01-2013, 12:02 PM
  #348
Moderator
denmah's Avatar
also its a simple 3 inch vband downpipe, and a 2.5 inch outlet, no crazy 3.75 inch downpipe or needlessly large 3.5 outlet, dont get me wrong, the gt45 is a great turbo and has pushed many of our cars into the 10 sec range and it is cheaper than the on3, it is hard to fit in the engine bay on some cars though haha
Old 11-01-2013, 12:27 PM
  #349
LS1TECH Sponsor
DrTurbo's Avatar
Got a feeling the car is about to pick up some power
Old 11-01-2013, 01:34 PM
  #350
Moderator
denmah's Avatar
HAHA yes, i just got it today so i can post it up.
but i got a nice mill from DrTurbo here to see the difference between a on3 76mm.. and this S476R, is this a fair test? haha
I believe, if Jose wants to correct me
this is the Billet S476r V3 wheel, with the t4. 1.0 or 1.10 AR and 87mm turbine wheel.
should be killer on a 4.8 and more than likely gen4 5.3 going in here.
fairmont 3.0 (5.3, isky 3x12, s476r) 721rwhp @ 17psi pumpgas 9.68@145mph-skm5g1f.jpg.
fairmont 3.0 (5.3, isky 3x12, s476r) 721rwhp @ 17psi pumpgas 9.68@145mph-gyvtr1y.jpg
Old 11-01-2013, 02:01 PM
  #351
CameronVic's Avatar
You get an 8! You get an 8!
Old 11-01-2013, 04:57 PM
  #352
sbcgenII's Avatar
Denmah can you take a picture of the S4 next to the on3? Waiting to see what you think about the new turbo.
Old 11-01-2013, 06:20 PM
  #353
slow1g's Avatar
THIS is inspiring. been following this build and the last one. that borg warner is oh jesus
Old 11-01-2013, 06:30 PM
  #354
95bowtie's Avatar
Is it 87mm on the inducer or exducer of the turbine?
I always get confused with the borgs everyone will say 96mm turbine or something yet that's the inducer. Which I'm sure it matters what size it is but not nearly as much as the exducer size.
Old 11-01-2013, 07:40 PM
  #355
CameronVic's Avatar
BW calls their turbines by the inducer (bigger). Precision goes by the exducer.
Old 11-01-2013, 07:56 PM
  #356
stangtrader's Avatar
I cant wait to see what this turbo does
Old 11-01-2013, 09:50 PM
  #357
Moderator
denmah's Avatar
fucked with the brakes endlessly today, had lots of trouble, now we got to a good point and the front calipers are locking up, so pulled them off and going to try and put GT calipers and rotors and pads on tomorrow
oh and put v8 rear springs in and filled up the right side with childrens outdoor toys
Old 11-02-2013, 03:05 AM
  #358
Tanus's Avatar
that's like the main reason I wanted to get the gt45! lol, with a gt45/on3 at say 600rwhp, is there any gain in running a DP bigger than 3 inch? And which do you think had more HP, your last fairmont or that 3rd gen camaro with the twin 57s? Actually which do you think had more potential HP? I like the twins cause I can use the internal wastegates so I'll save money on that plus I won't have to route wastegate into the DP like with a single. But the single has a lot simpler coldside. Kinda evens out so for me comes down to higher potential HP
Oh and nice turbo taking it up a notch!
Old 11-02-2013, 08:59 AM
  #359
gofastwclass's Avatar
Looks like a nice piece. Can you take a few pictures of both turbos side by side with a tape measure between them for those who don't happen to have one (or two) lying about?
I love the outdoor toys idea.
Old 11-02-2013, 09:18 AM
  #360
norotor7's Avatar
Are you going to put the One3 on the dyno and track so you get a real numbers comparison between the turbos? And when they spool.
I'm sure a lot of us would like to see that.
Quick Reply: fairmont 3.0 (5.3, isky 3x12, s476r) 721rwhp @ 17psi pumpgas 9.68@145mph
