MY Real Street 275 build
Old 09-04-2014, 06:05 PM
  #661
Sales@Tick's Avatar
Yea it's got stock valve covers on it now.
Old 09-05-2014, 11:24 AM
  #662
RonSSNova's Avatar
Good to see you have the rollers spinning Martin!
As well as keeping the oil (and the internals) in the motor. :-)
I'm sure you will continue to sneak up on the tune and will be well prepared before you make those first track passes.
Ron
Old 09-05-2014, 10:41 PM
  #663
Sales@Tick's Avatar
Well, I can now say that I have the highest powered car that has ever been on Tick Performance's dyno.
Easily eclipsed 4 digits on 25psi and a conservative tune up. AFR is still in the 11.2-11.4 range and could easily be leaned out to 11.8-12.0 if we need the added power. Could easily put 2-3 more degrees timing in it if the added power is needed. My IAT's have still not eclipsed 124* on a full pull to 7500rpm on 25psi. They start the pull around 90-95* ambient temperature and end just above 120*.
On 25psi back pressure is still under 2:1 and shows that this turbo has more boost to make if the added power is needed.
Extremely happy with the way this build turned out and all the blood, sweat and tears finally have started to pay off. We tried to take it to the track tonight, but testing the creep function on the transbrake we have found that my trans brake solenoid which has sat for almost 3 years without being used is sticking randomly. Some times it will work, sometimes you have to put it in N or R and hold the trans brake button, aggressively back up as if to un stick the solenoid and then it will work in low gear again. What's more interesting is trans brake works in R and N every single time, but won't always work in low gear.
Hoping to solve that on Monday and then take it to the track Thursday of next week.
Old 09-05-2014, 10:57 PM
  #664
ws602's Avatar
How are the twin 450 pumps holding up are they maxed out yet?
  #665
ls1CANTU's Avatar
That's awesome Martin. Congrats
Old 09-06-2014, 05:44 AM
  #666
98Camarod's Avatar
Nice Martin! Any dyno video? what were the final numbers?
Old 09-06-2014, 06:41 AM
  #667
Old School Heavy
speedtigger's Avatar
Congrats Martin. I am glad to see your engine is a success. Now the real fun starts.
Old 09-06-2014, 07:19 PM
  #668
Sales@Tick's Avatar
Thanks Steve. Just have to get the power to the pavement now.
Old 09-06-2014, 08:07 PM
  #669
ss performance's Avatar
The hard parts done, now it's just tweaking things.
Nice job!
Old 09-06-2014, 10:11 PM
  #670
Dustin11's Avatar
Very nice!! Keep me posted on the results.
Old 09-07-2014, 02:11 PM
  #671
Sales@Tick's Avatar
I won't release the final numbers, but one of the last pulls we made was over 1050 to the tires on 25psi.
It will easily make over 1100rwhp.
We also scaled the car on Friday and my estimates on weight were DEAD on. With me in the car, and a full tank of gas she weighs 3190 with no lead and the car has to weigh 3250 per the rules for my combination.
Old 09-07-2014, 02:41 PM
  #672
Rise of the Phoenix's Avatar
Nice work Martin. I bet it scares the crap out of you when you make that first pass.
Old 09-07-2014, 03:52 PM
  #673
b16gsr's Avatar
Well done dude, been waiting to see this come together. Congrats.
Old 09-07-2014, 04:02 PM
  #674
98Camarod's Avatar
Nice work!
Old 09-07-2014, 04:31 PM
  #675
I8URLS1's Avatar
Congrats Martin! I can't wait to know that feeling one of these days when mine is done.
-Jarred
Old 09-07-2014, 07:15 PM
  #676
Sales@Tick's Avatar
Thanks guys. If I had a bit better parts in this motor like a better crank, 6 bolt heads and better rods we'd of turned it on up to 30psi on the dyno and put it on kill. I wasn't too concerned with making a big number on the dyno, but I at least wanted to make 4 digits.
We made a pull on 19psi with 15* timing in it and it made 825rwhp, way low on timing for that amount of boost and the fuel I run. Next pull we put it on 25psi and added timing not knowing what to expect. When I saw the numbers come up on the screen and they were well over 4 digits I had a smile you couldn't wipe off my face.
I had always hoped that it would make 1000rwhp, as I knew at 3250# if it made that kind of power it would go 5.16-5.20@134-136 which would be semi competitive at the big races, and very competitive locally. I assumed it would take more than 25psi and leaning on the tune up pretty hard to make that number though. The fact that it made what it did without even leaning on the tune up at all, and on 25psi with less than 2:1 back pressure leads me to believe that this thing just might be able to run low 5.0's@139-140mph leaning on the tune-up.
Time will tell.
Old 09-08-2014, 07:27 AM
  #677
SCott5's Avatar
I will be up there Friday picking up a ls6 crossover tube setup from you guys, I better get to see this!
Old 09-08-2014, 09:40 AM
  #678
Sales@Tick's Avatar
It's not going anywhere.
Old 09-08-2014, 10:15 AM
  #679
SCott5's Avatar
You got fast valley bolts in stock?
Old 09-08-2014, 10:58 AM
  #680
Sales@Tick's Avatar
I don't think so.
Quick Reply: MY Real Street 275 build
