SN95 5.3 TH400 3.27 build thread - 10.88/134.86 - NOW LQ9
Old 04-28-2014, 08:01 AM
  #81
69-chvl's Avatar
Up and running!
Being that the car is not registered, I didn't drive it long. Idles like a dream at about 740 rpm (in gear). Drives nice, but the sucker is too loud for me (just 2 bullets installed in the pipe) so I have to do something with that.
I think the converter is a bit loose, more on that later. Only brought it up to about 4800 rpm/10-11psi and about 58% throttle - just want to make sure everything holds together before really letting it run.
I was getting what I thought was a miss-fire at 4800 or where the w/g's open, but I guess it could be just the gates opening and that's all. I never had a car with the gates vented to the atmosphere so maybe that's what I was feeling. I have the 7psi springs in the gates and the HomeDepot boost controller.
Old 04-28-2014, 12:20 PM
  #82
SM105K's Avatar
Originally Posted by Busa_rob
I used flipped c6 manifolds. They just clear my aje k member and compressor.
This is in a sn95 correct?
Old 04-28-2014, 01:17 PM
  #83
RonSSNova's Avatar
I thought the same thing when I got in mine hard enough to open the gates the first time. Also vented to atmosphere.
Good to hear it's moving under it's own power! Looking forward to further impressions!
Fun stuff!
Ron
Old 04-29-2014, 06:04 AM
  #84
69-chvl's Avatar
I thought the same thing when I got in mine hard enough to open the gates the first time. Also vented to atmosphere.Ron
Kinda feels like a misfire right? The AFR held steady so I guess it wasn't a misfire. Need a little more seat time.
11 psi at ~58% throttle. Need to lower the boost setting a bit as I'm still ironing things out.
Old 04-29-2014, 10:36 AM
  #85
RonSSNova's Avatar
Yeah, it's an odd sound. You are logging your drives, right?
Old 04-29-2014, 02:13 PM
  #86
69-chvl's Avatar
Yep.
Everything "looks" good - AFR, fuel pressure rises under boost, meth is turning on. Need to make sure nothing will fly-off before dropping the hammer fully.
Old 04-29-2014, 06:44 PM
  #87
RonSSNova's Avatar
That's what the parachute is for!
Old 05-05-2014, 02:18 PM
  #88
69-chvl's Avatar
Been driving around and this thing is a BEAST when the turbo is lit.
Seems like the turbo is making positive pressure at 3800 and:
1st gear
4400 = 5psi
4500 = 7psi
4800 = 9psi
4930 = 10psi
5459 = 12psi
2nd gear
4927 = 13.92
5129 = 14.94
Seem normal? Just prelim #'s with basic tuning. I would think a t4 turbo with 83mm turbine fully divided with 2.125 pipes would spool a little faster, but I think the converter is a bit loose. But, it drives pretty good - good enough for now.
Getting some popping at times getting into boost, may need to tighten the plug gaps. I also need to keep an eye on the Home Depot boost controller to make sure boost is being controlled consistently.
All in all its a good time
Old 05-05-2014, 04:08 PM
  #89
69-chvl's Avatar
Old 05-05-2014, 08:53 PM
  #90
RonSSNova's Avatar
1st gear
4400 = 5psi
4500 = 7psi
4800 = 9psi
4930 = 10psi
5459 = 12psi
2nd gear
4927 = 13.92
5129 = 14.94
Seem normal?
Are these numbers foot to the floor?
In low I have no hope if any semblance of traction. Ditto for 2nd. Rolling the throttle.
Of course this is on street tires.
Going to the track with slicks on Wed. I'll have more to compare then.
Ron
Old 05-05-2014, 09:03 PM
  #91
69-chvl's Avatar
Ron
At first yes then I back off a bit...just no room around here. The drag radials are spinning everywhere also...street tires would be a total waste.
PS - that popping sound I was complaining about, I think I was getting spark blow-out. I had the plugs in there at .035 for some reason. Closed them to .028 to see what happens. Need to get an air filter on there...lotta little stones around here!!!!!!!!!!!!!
Old 05-05-2014, 09:21 PM
  #92
RonSSNova's Avatar
Same as me. Too many cars, no matter where I go. I do have a bowl/screen on mine.
Of course the BOV is partly open at cruise too. I suppose I should put a screen on it too....or stiffen the spring a tad.
I haven't floored mine from a low roll at all.
Old 05-06-2014, 06:56 AM
  #93
69-chvl's Avatar
I was expecting some issues with my RPS BOV but the things seems to be working mint with the installed spring. I figured with 22" of vacuum it would be open at idle but it looks very closed to me and seems to be working in all respects as it should.
With the air fliter I will need to be creative to get it to fit. I will be forced to run a 45* or 90* elbow and then the filter. Can't see it being too much a restriction as these BW's have a 5" flange/filter over the 4" inlet of inducer. Most turbos run a 4" filter from what I've seen.
Old 07-08-2014, 08:27 AM
  #94
69-chvl's Avatar
Dyno day Sat - wish me luck!!!
Old 07-08-2014, 09:09 AM
  #95
RonSSNova's Avatar
It's going to be good!
Old 07-08-2014, 09:40 AM
  #96
69-chvl's Avatar
If it survives the dyno on Sat I'm going to make a couple of passes at the track the following week.
Old 07-08-2014, 02:54 PM
  #97
ajrothm's Avatar
Good luck Vince!
Let er eat!
Old 07-12-2014, 11:26 AM
  #98
69-chvl's Avatar
Dyno day - Mustang on a Mustang!!! Mustang Dyno that is.
First couple pulls, dam engine was breaking-up. After remembering my water/meth debacle, I revisited that 1st. I reduced the meth injection by 33% and the thing finally pulled clean. Makes me wonder if I should of taken more out, but the car was running cleanly now.
ALL RUNS 16 PSI AND 11.5 AFR, ABOUT 9% TOTAL WATER/METH FLOW
RUN 1:
447HP-5300rpm/507TQ-3200rpm WITH 12*
RUN 2:
488HP-5300rpm/661TQ-3160rpm WITH 14*
RUN 3:
497HP-5281rpm/654TQ-3462rpm WITH 15* AT 5300
Misc info:
lbs/hr of fuel = 380 + another 9% of water/meth, IAT 93* to 100* during the pull (seems low but was 95* before the pull and climbed to 103* after the pull), DC = 58%
I would of liked to move the AFR around but the operator said it doesn't make a huge difference. Also wanted to try w/o the air filter on but he said don't bother either - (I wanted to but didn't want to fight).
Think I'll reel the timing back to 14* and call it good. 41*hp/154lbft gain from 2* of timing!!!!
But, the HP seems low and I know not to get hung up on dyno #'s. Wondering how bad my converter is b/c he had a ds1 408 on there with 10psi and it made like 600 rwhp but it was a manual trans.
Peak power was around 5300 which I think is about right for an LS6 cam. Boost was erratic on the dyno print out by my data logger shows it to be ALOT smoother. Like to make a couple of passes at the track in the next couple of weeks.
All comments welcome please on what I should/shouldn't of done and any other observations.
One thing that has me thinking is that the HP keep climbing but peak power was at 5300. Not sure what going on if its a Mustang Dyno thing, converter etc b/c you would think power would nose over at 5300, but it didn't. Guess that's a forced-induction thing???
Attachment 459808
Attachment 459809
Old 07-12-2014, 11:53 AM
  #99
ajrothm's Avatar
Your dyno guy is an idiot.... AFR, timing and air filters can make a HUGE difference...
Although at 11.5 afr, you are in a good sweet/safe spot...Same thing for the timing at 14-15*.... Id leave it there. Air filter I would pull off for sure... I gained 44hp from no air filter/inlet pipe.... All depends on how restrictive your filter setup is...
All in all I think you did good, especially thru a 4l80 and converter....
FWIW, my 71' only dynoed 460 rwhp thru a T400/10" converter and heavy IRS.... Yet it traps 127 at 3600lbs..... You'll go low 10s easily at 500rwhp.
Old 07-12-2014, 11:56 AM
  #100
ajrothm's Avatar
As for the low rpm peak... Did you install fresh valve springs? Even stock bone stock LS6 peaks higher then 5300... I think you should be peaking higher.... Maybe back pressure?
Quick Reply: SN95 5.3 TH400 3.27 build thread - 10.88/134.86 - NOW LQ9
