cam for twin gt45s
Old Oct 23, 2013 | 07:33 PM
rollwithit's Avatar
Default cam for twin gt45s
building a pro street c10 stock 5.3 with 2 gt45 turbos
specs
T4 GT45 Turbocharger
Universal Fits all cars and trucks
4" Inlet Diameter
3 1/2" V-Band Outlet
Wet Float Bearing
T4 Flange
Oil Cooling Inlet: M10*1.5 outlet: 2 M8
Max Power: 650hp
Compressor Wheel
0.70 A/R Cold Side
Ind: 51.99 mm
Exd: 81.74 mm
Trim: 40
Turbiner Wheel
3 1/2" V-Band 0.68 A/R Hot Side
Ind: 73.42 mm
Exd: 57.97 mm
35 PSI Peak Power Performance Output
CNC Machined Flanges
Turbo Comes With Its Own Serial Number
any ideas on a cam for these twins? was thinking matbe a ls6 or triple 12 cam.
Old Oct 23, 2013 | 07:40 PM
T76s10's Avatar
Post a link of them turbos. If they are the 69/78 version I wouldn't even bother with a factory
Old Oct 23, 2013 | 09:01 PM
turbocamaro125's Avatar
52mm turbos? I thought the ebay gt45 was a 69mm turbo with a 1.05a/r t4 housing
Old Oct 23, 2013 | 09:19 PM
rollwithit's Avatar
74mm
not eBay turbo.
speedyracer.com
Old Oct 23, 2013 | 09:34 PM
Compressor Wheel
0.70 A/R Cold Side
Ind: 51.99 mm
Exd: 81.74 mm
Trim: 40
This the compressor wheel specs?
Turbiner Wheel
Ind: 73.42 mm
Exd: 57.97 mm
and that the exhaust specs?
Old Oct 23, 2013 | 09:38 PM
rollwithit's Avatar
http://www.speedyracer.com/turbo/tur...0hp-68-AR-GT45
denmah used a gt35 ebay turbo in twin setup and was too small. IMO this turbos are to small. Not sure on the power your looking to make tho.
Denmah made like 500whp and 820tq and like 15psi on the white 2500LD
Old Oct 23, 2013 | 09:45 PM
rollwithit's Avatar
Compressor Wheel
0.70 A/R Cold Side
Ind: 51.99 mm
Exd: 81.74 mm
Trim: 40
Turbiner Wheel
Ind: 73.42 mm
Exd: 57.97 mm
i think so.. IM kinda of a turbo dummy!!lol. Posted a link to the web site
Old Oct 23, 2013 | 09:47 PM
yes i searched it before you sent the link....live and you learn. those are 52mm turbos. if you want to pull stumps those turbos will work good....lol
Old Oct 23, 2013 | 09:49 PM
GT45 Turbocharger:
T4 Exhaust Flange, 4" V-Band Outlet, 4 3/16" Inlet
Supports 650+ HP
Compressor Wheel Trim: 50
Compressor A/R: 0.66
Turbine Wheel Trim: 77
Turbine A/R: 1.05
Compressor Wheel Inducer: 68.9mm
Compressor Wheel Exducer: 98mm
Turbine Wheel Inducer: 88mm
Turbine Wheel Exducer: 77.4mm
ebay gt45 specs. If you building a max effort build then the ebay gt45 will be what you need a twin setup. And a 3-12 cam would do a hell of alot better the any stock cam.
Old Oct 23, 2013 | 09:52 PM
rollwithit's Avatar
Compressor Wheel
0.70 A/R Cold Side
Ind: 51.99 mm
Exd: 81.74 mm
Trim: 40
Turbiner Wheel
Ind: 73.42 mm
Exd: 57.97 mm
I think so.. Im kinda of a turbo dummy,lol!!! i posted a link to the web site.. Is it not a good turbo?
Old Oct 23, 2013 | 09:54 PM
What kinda power you trying to make?
Old Oct 23, 2013 | 10:09 PM
T76s10's Avatar
I had the same turbos denmah used. I ran like 20 degrees timing and was over boosting in the 25-30psi range and running lean. It honestly felt like a big block. It's instant power it's rediculous. Those were 61mm comp and 62mm turbine. For your 5.3 the cx racing gt35's will work out good. I wouldn't get those gt45's you posted. It honestly depends on the power you want to make and what you want to do with the truck. If I were you I would get the on3 70mm turbos in .68 ar and get cam and converter made for you so spool doesn't suck.
Old Oct 23, 2013 | 10:16 PM
rollwithit's Avatar
6-650 max
Old Oct 23, 2013 | 10:28 PM
rollwithit's Avatar
6-650 max can I get that? Gonna be running twins with intercooler
Old Oct 23, 2013 | 10:38 PM
T76s10's Avatar
Those cx racing gt35's will work out good for you then. Just keep stock cam or ls6, ls9 it don't matter it will spool fast either way
Old Oct 23, 2013 | 11:17 PM
smokeshow's Avatar
This information is misleading. I made twice the power on the same boost, same turbos and same engine. There were other issues with his setup.
Old Oct 24, 2013 | 05:48 AM
rollwithit's Avatar
What cam did you run?
Old Oct 24, 2013 | 05:49 AM
Yea he had a big tick cam and ran the turbos to hard on the 6.0
Old Oct 24, 2013 | 09:04 AM
rollwithit's Avatar
GT45 Turbocharger:
Supports 650+ HP
Turbine A/R: 1.05
Once again, this is not a eBay gt45 turbo... different specs. My a/r is 0.68 the specs you listed are different than mine. And the other guy, its not a gt35 either.. were discussing a t4-.68 a/r gt45
