Vortech owners who is running the 2.5"pulley with G-trim?
I want to know who is running the 2.5" pulley and if they have a G-trim with strait cut gears or the SQ version (This is the standard V9 kit sold for the Camaros) and how old is it ETC... How many have herd of or have had problems with it and does anyone know of one that has Grenaded lately by overspinning the impeller? I want to run one but I don't want to if all the guys running the 2.5" pulley are all using the HD strait cut gears. Thanks.
Jeff
Jeff
10 & 11 Second Club
Mike M a friend told me that in another post you had mentioned that you ran an EWP with your Vortech kit. If this is correct did you have to do anything to get the SC belt to clear the EWP. Thanks Dave
10 & 11 Second Club
Mike M with the 2.65 pulley how much boost where you runing, and is that a Ttrim or Gtrim.I would probably see about 3lbs less with my setup then you with a 4.10 bore you think?
I have the straight cut G-trim. and its about 3 yrs old now. Caveman I never got to make a full out pass to see how much boost I gained from the 2.85 to the 2.65. I would guess it was atleast 2 more lbs over the 2.85 which only gave me about 6-7lbs. Im not sure you would loose that much boost having a bigger bore. maybe some of the guys witht he strockers and stuff could answer that better.
SJH is your car a dailly driver or a weekend car? How hard are you on it when you do drive it ETC...
When I do drive it, it's sees full boosted runs every time out.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
Originally Posted by Inspector12
Mike did you order it like that or is that how your kit came? Is there an easy way to tell if you got strait cut gears?
