Turbowerx exa pump questions.
Old Jul 29, 2014 | 02:03 AM
BlkBird2000's Avatar
Default Turbowerx exa pump questions.
I have a t4 tc78 turbo with -4 feed and -10 drain. The oil return is level because I have a low mounted turbo. I'm buying a turbowerx exa scavenge pump to fix my issue.
First question does a -10 line to the pump then -10 line to the oil pan work or do I need to purchase new fittings and hoses?
Second is do I have to mount the pump below the turbo or can I mount it above the turbo and will the pump pull the oil up from the turbo?
Third is do I have to do any kind of venting for this pump? I'm in the process of trying to figure out how to run all my vacuum lines and don't want to redo anything.
Old Jul 29, 2014 | 05:00 AM
Also should I buy the 12v or the 24v?
Old Jul 29, 2014 | 07:07 AM
herecomesboost's Avatar
-10 to/from the pump is fine. I used this pump on one of my S2000 builds (low mount turbo) with zero issues. The pump can be mounted above the turbo. No need to vent anything.
Old Jul 29, 2014 | 04:52 PM
stevieturbo's Avatar
One would assume you are using a 12v electrical system...there's a clue.
Exa pump can be mounted anywhere ( within reason ) and any orientation. So higher, lower, doesnt really matter.
-10 is fine, just order -10 fittings with the pump.
And no venting required.
Old Jul 29, 2014 | 09:13 PM
I did order the 12v with -10 fittings. I don't know squat about electrical so that's why I asked. Thanks.
Old Aug 5, 2014 | 10:32 PM
Guys with this pump, how did you go about wiring it up? The end of the harness it came with has two wires I need to hook up. One red and one black. My buddy wired it like the fuel pump is wired so it comes on when the ignition is turned on. We put a fuse on it. Is this ok or should I wire it differently? Thanks.
Old Aug 6, 2014 | 02:51 AM
Nothing wrong with that.
Old Aug 6, 2014 | 06:41 AM
JAX04's Avatar
Basically how i've done the last few that i've hooked up on my cars. Only difference is i use a Relays on just about everything.
