E85 fuel filter report
Old Sep 6, 2017 | 08:51 PM
  #41
Forcefed86's Avatar
No reason to filter a return line that I'm aware of. You would just be adding restriction. Lots of people run them and it will probably be fine. But it's not ideal or "manufacturer suggested" That's why I hate to see people spend the money on more expensive filters that don't filter or flow as well at the ones I linked originally at the start of this post. Kinda depends on the type of build as well. On drag only stuff it's not as critical as a car you drive daily.
Old Sep 7, 2017 | 04:51 AM
  #42
waterbug1999's Avatar
I have that huge one (cant see the picture) but its really big and kinda hard to fit. I can get a 10 micron small fuel filter no problem.
Old Sep 9, 2017 | 03:26 AM
  #43
Dian's Avatar
Originally Posted by roastin240
Do you run this filter? How does this filter make you feel inside?
i just installed it and so far it works. a lot of filter for the money.
Old Sep 9, 2017 | 02:14 PM
  #44
Cwarta's Avatar
This filter setup support 1000whp safely on e85?
Old Sep 12, 2017 | 02:50 PM
  #45
roastin240's Avatar
How about this housing:
https://www.summitracing.com/parts/frm-hpg1
With this filter in it:
https://www.summitracing.com/parts/wix-33900r
I found this on another forum:
"I just got off of the phone with Wix filters and they said that their 33900R filter which goes in a Fram HPG1 canister IS E85 , alcohol , methanol compatible because it is in their racing filters catagory. :biggrin: So get the Fram HPG1 filter housing , toss the Fram filter and replace it with a Wix 33900R and it will filter down to 5.9 microns @ 90gph @ 150psi. $41.95 for the filter canister and $4.95 for the filter through Summit"
90gph wont take you too far though Maybe there is a larger/longer element and head unit. I will give Wix a call.
Old Sep 12, 2017 | 07:38 PM
  #46
Nitroused383's Avatar
The golden rod one posted in here is 6 gpm or about 720 gph. It's proven for under $30 so why reinvent the wheel.
Old Sep 13, 2017 | 08:48 AM
  #47
roastin240's Avatar
Ya I saw that. It is 10 micron nominal but not absolute. After the high price tag on these ID injectors, I want better filtration that the "golden rod" provides. Someone mentioned the CAT filters...anyone have a part number?
Old Sep 13, 2017 | 08:54 AM
  #48
Cwarta's Avatar
When I built my twin filter kit for my cummins, I was able to get some 2micron filters for it, Baldwin or Donaldson. I'd have to look at part numbers
Old Sep 13, 2017 | 09:18 AM
  #49
Forcefed86's Avatar
Look at the micro glass filters at the tractor supply. They advertise 2 micron nominal. Used on the same base as the goldenrod filter. If you want to overkill… Run a standard 595 goldenrod style first. Then the 2 micron second. Pretty typical for diesel stuff to have the staged filters. Just have to be careful with the flow rates of the smaller micron filters. Might need 2 in parallel.
Details here
https://ls1tech.com/forums/forced-in...l-filters.html
