HPTuners for boost
When tuning the other day, I'd advanced my 5600+ RPM spark advance a couple of degrees. It really pulls hard, but I did find some knock retard. Turns out, that particular KPA/RPM range, though commanded to .768, was running 8.xx(lean). I fattened up those cells, took another test run and no knock retard.
I've tried both using the cut and paste special feature built into HP tuners and a special spreadsheet that I use to target my own AFR/Stoich settings. Since my tune is setup for Lambda, when I use HPTuners 'paste special', it seems to add or subtract '1' from the cells affected. After applying the change, upload and test, the same cells will be off. Using the built in utility, it again, adds or subtracts '1' to the affected areas. My spreadsheet generates values larger at times and seems to target the affected area to a better result. I'll keep fidgeting around and trying to figure out the best method.
http://files.hptuners.com/support/De...alkthrough.swf
are you doing paste special multiply/multiply by half?
i was doing paste special ADD....whoops not good
Yes, I've tried both the multiply by full and half. It's funny (to me anyway) that when I was tuning by AFR(14.7), it seemed that my adjustments were more granular than the Lambda I'm now using. But, I'm not complaining. The engine is running really strong. Almost finished putting in the plugs. Got one more to go. I decided that with this CXRacing hotside, it's more expedient to just unbolt only one header at a time, leaving the other header and the downpipe to suspend the turbo, and swap out the plugs than trying to finagle each plug with the hotside all bolted up. There's no way I could do this at the track without nomex gloves. Hopefully, I won't have to swap plugs too frequently.
https://ls1tech.com/forums/forced-in...l#post19698460
