What oil pump do you recommend?
Old Dec 25, 2014 | 09:13 PM
adrynalinjunkie's Avatar
Default What oil pump do you recommend?
Well since I am swapping the T chain and sprockets....
Would it be worth the money to switch from a stock oil pump to a high output aftermarket oil pump on a big HP Turbo build?
What are you running?
Old Dec 26, 2014 | 01:11 AM
RonSSNova's Avatar
I bought the GM Perf pump from Brian Tooley. Because it was $90.
I took it apart and ported it as well.
Old Dec 27, 2014 | 06:40 AM
Camaro9969's Avatar
What oil pan will you run?
Old Dec 27, 2014 | 11:17 AM
forcd ind's Avatar
I have just used stock GM pumps, ported them, and a small spacer on the spring
If using a double row chain, there used to be problems with aftermarket pumps and the front cover
Old Dec 27, 2014 | 01:26 PM
Pocket's Avatar
I use stock replacement mellings with a few washers under the bypass spring
Old Dec 27, 2014 | 05:39 PM
TrendSetter's Avatar
stock with a single #6 washer under the spring. i used two before and didnt like the pressure that high. im weird.
Old Dec 28, 2014 | 12:04 AM
boss79z's Avatar
Schumanns. Had a ported ls6 on my last setup. Excited about the new pump.
Old Dec 28, 2014 | 08:48 PM
soundengineer's Avatar
+1 for Schumanns Pump....
really cannot go wrong with them.
I also went with a Moroso 7qt oil pan and pickup
I see 45 psi at Hot Idle, and over 100 psi by 4000 RPM rolling into WOT
its AWESOME
(high oil pressure does not hurt anything - Just be sure to use a good oil filter that will not collapse under pressure - I use WIX because they do not collapse until over 300 psi)
Old Dec 29, 2014 | 12:03 AM
Blown06's Avatar
8 Second Truck Club
its AWESOME
I'm in your camp. Oil pressure is like money and *****.........
Old Dec 31, 2014 | 05:15 PM
Autokraft Pan
Old Jan 1, 2015 | 09:29 AM
Slowhawk's Avatar
LS1Tech Sponsor
I always use a 02 GM style pump that we port in all our builds. Even in the race cars. No issue's.
As for 100psi. That seams extreme to me but looks like it works. I get about 70-80 on my race car at 7800rpm. Bearings look perfect on teardowns.
Old Jan 5, 2015 | 07:33 PM
Just order one today from Schumanns. It was $279
He said it will come with the purple spring that will give me around 100 PSI cold... He said you definitely want to run a higher than stock capacity pan with this pump.. or it could cavitate..
He said they will include 2 other springs that would make even higher psi, but he said without a larger external filter the purple spring is the one to use...
He also said K&N oil filter or a WIX.. for my stock canister type
He said they could port it for $20 more but that requires you to Tig weld a 2 bolt flange onto the Pickup tube as the o-ring will no longer be used....
Old Jan 5, 2015 | 07:37 PM
you dont have to TIG the piece for the schumanns pump... you can MIG weld it...
its definitely an option you want to do if you can mock it up properly to tack it before welding it
I actually had a junk block and crank here, so I just put my stock pump on it, and put on the pickup and welded it while it was on the junk block.
Old Jan 6, 2015 | 05:18 AM
usually more trouble than the work to get it
Old Jan 6, 2015 | 07:39 AM
the ***** part... yes....
the oil pressure part...no
high oil pressure is not more trouble than its worth....
doesnt cause any issues as long as you use a good filter...use a Wix or a K&N that has been tested to over 300 psi and its not a problem...
other than that, there is nothing you can damage from having more oil pressure
Old Jan 6, 2015 | 10:43 AM
rpturbo's Avatar
At 100+ psi of oil pressure, doesn't that tend to push some seals? I guess if you get a oil leak, you GET A OIL LEAK! LOL
Old Jan 6, 2015 | 10:48 AM
You tell me what seals are inside your motor to push out?
The pressure is only in the oil galley
Front and rear cover don't ever see pressure
There are no seals to push out of the engine from oil pressure
Old Jan 6, 2015 | 12:22 PM
Ryans99ls1's Avatar
My ported ls6 pump from TSP has done great. 40ish at idle, 80+ with some rpm
Old Jan 7, 2015 | 07:05 PM
CaliboyTA's Avatar
tsp ls6 ported oil pump here. over 70k with it and no problems
