SDCE stuff arrived
Old Jun 10, 2004 | 12:54 PM
BIGBOS's Avatar
Default SDCE stuff arrived
Got my bracket and crank pulley in the mail today, I got to wait until friday for the 3.4" pulley and the belt, I guess ATI doesn't make a 3.2" offset pulley, but Wendy is going to do some more talking with ATI to see if they can get one......
Either way I'll see how this works, I'll be installing the crank pulley tonight at friends shop and then installing the blower and what not tomorrow when I get the belt and blower pulley....
I'm going into the shop on monday-wed for dynoing
BIG props to SDCE, this stuff looks great and I can't wait to get it on the car, I really hope it works out for me Thanks for getting the stuff to me quick
Also, does anyone else not see the instructions on the SD webpage, I can't seem to find them, I got a sheet printed out, but I wanted to take a closer look at the blown up images
Old Jun 10, 2004 | 01:07 PM
NA$TY-TA's Avatar
I just checked on there site and i couldnt find the link to there install page either BOS.... maybe there updating it??
Kyle
Old Jun 10, 2004 | 01:08 PM
BIGBOS's Avatar
Kyle, do me a favor and sign on AOL
Old Jun 10, 2004 | 01:11 PM
NA$TY-TA's Avatar
BOS PM sent
buschman's Avatar
great news. I know mine shipped today. Can't wait to check it out
Mike
Old Jun 10, 2004 | 01:15 PM
ChevyNo1's Avatar
BIGBOS, can't wait to hear how the dyno comes out . . . I've got the same engine on the way What is the CR of your combo? I'm going to be around 8.9:1 . . .
Old Jun 10, 2004 | 01:33 PM
BIGBOS's Avatar
I'm 9:1
Old Jun 10, 2004 | 01:34 PM
NA$TY-TA's Avatar
Mike
Good news Mike..... when does it look like you will be putting yours on?? Dyno?
Kyle
Old Jun 10, 2004 | 02:12 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Sounds great.
Might as well pin the crank while you are down there.
Old Jun 10, 2004 | 02:17 PM
BIGBOS's Avatar
Yea, Larry@SpeedInc ordered up a pin kit so they can do it before it hits the dyno
They got me in right away too
Old Jun 10, 2004 | 02:41 PM
buschman's Avatar
Kyle
I'd say within a couple of weeks of receiving it. I have to have the thing powder coated, got to put the new heads on, inspect the cylinders, hook up the alky, and then I'm ready to hit the dyno. I'll be workin hard the next few weekends
Mike
Old Jun 10, 2004 | 02:57 PM
BIGBOS's Avatar
Busch, did you go with the 3.4" blower pulley?
Old Jun 10, 2004 | 03:07 PM
NA$TY-TA's Avatar
Mike
Good to hear..... I believe Mike went with the 4" blower pulley but im not %100 positive Bos.
kyle
Old Jun 10, 2004 | 03:09 PM
buschman's Avatar
Not sure what size I'm getting. I think the 4" pully. I'm still a stock engine so i'll be gunning for 8-10 psi for now.
Mike
Old Jun 10, 2004 | 03:15 PM
NA$TY-TA's Avatar
Mike
Mike were are you going to be shifting at?? After market cam or stock? After market 6.0L heads ported??
Kyle
Old Jun 10, 2004 | 03:19 PM
buschman's Avatar
Kyle
6200, Stock cam, Stock 6.0L heads that I'm just gonna clean up, no port job.
Mike
Old Jun 10, 2004 | 03:27 PM
NA$TY-TA's Avatar
You should see the boost you are wanting Mike.... I calculated that you will be spinning your kit to 46K RPM's and on my stock motor with the MMS crank pulley and a 4" blower pulley i was spinning mine at 49K RPM's..... but probably was getting slip and i saw 11 psi at 6200 RPM's and i had a baby 212/218 .522/.529 114 lsa cam and LT's and a LS6 intake as my mods.
Kyle
Old Jun 10, 2004 | 03:47 PM
buschman's Avatar
Kyle
want? I want to see 18 psi of boost, but that ain't gonna happen on this engine :p It won't be long though. For now a conservative 8-10 should hold. Hopefully I'll be able to get the motor built this off season and I can run with you big boosters. I'll let you guys know how things go.
Mike
Old Jun 10, 2004 | 05:03 PM
MstgKillr's Avatar
I am seeing about 9 lbs at sealevel. Mods in sig
Old Jun 10, 2004 | 06:02 PM
BIGBOS's Avatar
I got the crank pulley installed today, I was suprised as to how much it sticks out of the stock balancer, but after torquing to 220fltbs I started it up and the thing is sitting perfect in there, no wobbling at all, I used this balancer from the start with the original 6 rib, then to ASP 8 rib, then to ASP COGS, now I'm still using it with the SDCE stuff....
I'm supposed to have a package at my doorstep tomorrow morning, so that means I'll be getting to work on getting the blower put back in the car and getting things bolted out, it looks like I might have to use a spacer or two to get the clearance I need, I was expecting the pulley to sit close to the stock balancer, oh well......
I'll post tomorrow after I get the stuff bolted on and the car started up, its still untuned and running fairly rich with the 60's, so I'll probably give it a few part throttle blasts just to make sure the alingment is good and the belt doesn't walk off.....
