LSA heads...can the chambers be opened up...?
Old Feb 14, 2016 | 07:20 AM
LS6427's Avatar
Default LSA heads...can the chambers be opened up...?
Can't find this answer anywhere in search.
Dropping compression this way is my only way to go....?
I'm at 10.8:1, plan on full time E85, and would like to decrease it a little bit since I'm in HOT South Florida.
My current chambers are 68cc.
I have flat top pistons.
Plan to go 18psi.
Old Feb 14, 2016 | 10:36 AM
ctsvcaddy's Avatar
I believe WCCH stage 2 port opens the chambers up to 72cc. So it's possible
Old Feb 14, 2016 | 12:54 PM
MYSTIC-1SC's Avatar
When material from the chamber is removed the chamber size increases in turn decreasing compression. Other than possibly swapping to a thicker gasket, or going inside the bottom end I don't see any other options.
Old Feb 14, 2016 | 05:13 PM
LS6427's Avatar
I know it decreases compression. Thats exactly what I want. I was curious if the LSA heads enough metal to be able to open them up and not compromise its strength.
Old Feb 14, 2016 | 05:20 PM
LS6427's Avatar
Well thats good for a little compression drop....
I'll contact Richard...
Thanks
Old Feb 14, 2016 | 09:40 PM
Forcefed86's Avatar
Easiest to run a thick head gasket. Call up cometic you can get 3-4mm thick head gaskets if you want.
Old Feb 15, 2016 | 01:56 AM
Blown06's Avatar
8 Second Truck Club
Maybe call around and just get the chambers softened. It'll open them up a little bit, and widen the tuning window a little bit. Win/Win
Old Feb 15, 2016 | 07:51 AM
LS6427's Avatar
Will using a thicker gasket compromise in any way the reliability of the gasket to hold up...?
I mean if I am going from a 68cc chamber to a 72cc chamber with flat top pistons I should get a little bit of a drop from 10.8:1.
I will also be using full time E85.....
Old Feb 15, 2016 | 07:53 AM
LS6427's Avatar
"softened".....whats that?
Old Feb 15, 2016 | 08:57 AM
Forcefed86's Avatar
Shouldn't, though I have no experience using them with LS engines. I used 3.5mm thick head gaskets on my 2jz engine at 30+lbs with out any issues. Thick HG's are super common in the import world.Call up Cometic and see what they suggest.
Old Feb 15, 2016 | 09:35 AM
LS6427's Avatar
Great thanks for the tip.
Do you know about what drop I could expect from 10.8:1 cr if I used a 3mm gasket..?
Old Feb 15, 2016 | 09:52 AM
Forcefed86's Avatar
http://www.summitracing.com/expertad...ion-calculator
Use the compression calculator above to figure it out. 3mm is an extreme example I'm sure you wouldn't run a gasket that thick. Would put you around 9.3:1. (w 68cc heads)
Think .075 is the thickest you can go before the price about doubles per gasket. Should put you around 10.2:1. Just call them up or send an email. List your specs (same as on the compression calculator above) and tell them what thickness gasket you want.
http://www.jegs.com/p/Cometic-Gasket...48860/10002/-1
Old Feb 15, 2016 | 04:40 PM
LS6427's Avatar
Great...thanks.
Old Feb 16, 2016 | 10:00 AM
newschool72's Avatar
What about quench area with a thicker gasket? Its possible to create more trouble than you solve by going to a thicker head gasket. What happens is, when you increase the distance from the quench area on the head to the piston, you loose mixture motion in the CC. In many cases, that will INCREASE the tendency for the engine to detonate, even though you've lowered the compression. A small change in gasket thickness probably wouldn't effect quench much, but at the same time its not going to lower the compression much either.
Old Feb 16, 2016 | 11:38 AM
rotary1307cc's Avatar
Richard had my LSA to 74cc with no softening
Old Feb 16, 2016 | 11:52 AM
DBRODS's Avatar
If its full time e85 leave the compression alone.
Old Feb 16, 2016 | 06:37 PM
LS6427's Avatar
Still don't know what "softening" means...?
Old Feb 16, 2016 | 06:38 PM
LS6427's Avatar
I have 10:8.1 now......I spoke to Richard at WCCH today about his LSA 72cc Stage 2 heads.
If I use them with LS9 head gaskets it will put me at 10.3:1....
Wouldn't that be better if I plan 18-20psi....?
Old Feb 17, 2016 | 01:40 AM
Blown06's Avatar
8 Second Truck Club
Kind of hard to explain. It is where you machine at a very slight angle a dish over the entire area of the combustion chamber. Google it and you can find some pics. Or go to yellowbullet and do a search. Plenty info over there.
The whole point of the exercise is to first slow the flame front down (helping to widen the tuning window) and then in some cases it is done to gain a few cc's in the chamber.
Old Feb 17, 2016 | 08:12 AM
LS6427's Avatar
I think I see....like little tiny walls or hurdles in rows. Kind of like baffles for the flow....to slow it down.
After playing around with some compression calculators.....it seems I can drop my compression to 10.5:1 with using stock chambered LSA heads and LS9 .055 gaskets for my 4.030 bore.
Or drop to 10.34:1 if Richards Stage 2 LSA heads are used with 72cc chambers.
Or 10.02:1 if Richard does the max of 75cc chambers....(spoke to him this week)
I think with full time E85 I should be fine with any of these.
What do you think???
