help please!!!!!! keep chewing up rod bearings
https://ls1tech.com/forums/generatio...pic-heavy.html
here is what happened last year shortly after going turbo(about 1500 miles on turbo setup)
https://ls1tech.com/forums/generatio...-now-what.html
so over winter i did a complete rebuild. sent the shortblock to the machine shop and had them go over it. they didnt find anything except the #1 and #2 rod big ends were slightly egg shaped but they were able to recondition them back to round. They also cut the crank journal .010" and magnafluxed it. I assembled the engine with new clevite bearings and a new melling 10296 oil pump. Everything was working great again and had 60+ psi of oil pressure at idle and close to 80psi at wot. I put around 200 miles on the engine and started noticing my oil pressure was dropping at idle, sometime down to 10psi. So i drained the oil and cut the oil filter apart to find an abundance of copper shavings just like last year. I couldn't hear it knocking this time so i think i saved it from any critical damage.
so here i am again.......looking for some ideas
- could this be tune related??? i never had any problems with the engine in 4 years until i put the turbo on it last year.
any help is greatly appreciated
also am i correct in thinking that #1 and #2 rod bearings are the last in line to receive oil? Could overfueling cause this? i noticed on some of my wot pulls the afr was dipping as low as 10.0:1. The oil did not smell like fuel so i dont think that it was contaminated.
I could watch my pressure drop on the mechanical gauge with 5.5qts and the high volume OEM“DOD” pump just accelerating hard on the street.
I’m running the extreme racing baffle now, standard truck pump, and 7qts. I still see a drop in pressure on the line at the track on hard launches. Esp. if I pick the nose up a good amount. I don’t restrict oil to the lifters though, suppose I’ll try that next.
At this point I think an accumulator would have been easier/cheaper than farting around with all the baffles and other “tricks” with this pan. Probably work better too.
Although the harness isn't wired for it, the oil pressure pins are there in the ECU and are active.
I actually hooked mine up to a fuel pressure sensor.
Ron
Have you pulled the pan, or just checked the filter
Possible its from the thrust bearing, I have seen some pretty
bad ones
the rod bearings dont look great but i believe most of the damage was from lack of oil due to bad mains. Its weird that #1 main looks relatively ok and then 2,3, and 4 are trashed. I was unable to pull #5 main since the rear cover is still on. Nothing shows any signs of excessive heat, and there isnt any scoring on the crank just some copper sheen.
crank was turned .010" and clevite .010" bearings were used
here are the specs from when i assembled
all main bearing clearances were .002"
crankshaft endplay was .004"
rode bearing clearances were .002"
now what??
