Dry sump?
Old Dec 16, 2016 | 10:26 AM
moekluse's Avatar
Default Dry sump?
I'm putting together a 600hp forged 5.3 in a touring/road coarse/track car and I was wondering..
how far can you push a conventional wet sump oil system? I'm sure baffles will help tremendously but I was looking into drysump kits and boy are they expensive.
do you think a simple high pressure oil pump and baffled oil pan will handle it? This car will be a daily driver and will be pushed pretty hard on street.
any help is appreciated. Thanks
Old Dec 16, 2016 | 05:18 PM
rwb's Avatar
rwb
You won't have a problem with the oiling system. It will take a lot before you can cause it to fail.
Old Dec 16, 2016 | 08:53 PM
TURBOLSBIRD's Avatar
What pan are you planning on getting?
Old Dec 17, 2016 | 04:55 AM
stevieturbo's Avatar
How long is a piece of string ?
You dont mention what car, what tyres, what sort of g's you might see and for what duration, what pan you intend to use etc etc.
Far far too many variables to say one way or another.
Old Dec 17, 2016 | 08:18 AM
KCS's Avatar
KCS
Moderator
Well said.
Old Dec 17, 2016 | 12:33 PM
moekluse's Avatar
it's going in a mini cooper s, rwd conversion, going with continental extreme tires but the car has a new set of semi slicks all around (215 tire size) that I may try out first.
my local autox track has very sharp turns coming out of fast straights as well as a few zigzag parts to it as well. G's will be pretty high due to how light the car is. I have not picked a pan, I need a shallow pan, that's probably the biggest reason I wanted to go drysump because of a small pan. The internals are being balanced then motors ready to go in. First got to mention it's getting a t56. I have no whindage tray, pan, sump, oil pump..etc so Im open right now to the idea of drysump. Just wish they weren't so pricey lol
Old Dec 17, 2016 | 12:58 PM
Light well balanced chassis with sticky tyres that does see hard track use often, a dry sump is the only sensible option.
That isnt to say the likes of an LS6 or other wont work too....GM deemed it ok for their Vette but sticky tyres can make a huge difference vs regular road tyres.
That said....there is also a good difference between sticky road tyres and slicks too, and you seem to have fairly narrow tyres still.
I doubt any other low profile type sump would be worth considering though, and if ground clearance is a problem, then again dry sump will assist you here.
Given you're building it from the ground up....it would be worth doing it right from the outset, rather than trying to figure out a dry sump kit afterwards
Old Dec 17, 2016 | 01:58 PM
3 window's Avatar
The LS6 system is a far cry from a real dry sump. A real setup would be your best bet as you wouldn't have to worry about running the pan dry or cavitation issues with oil slosh.
 Michael S. Palmer
Old Dec 17, 2016 | 02:08 PM
moekluse's Avatar
I got a quote from ARE for a complete drysump kit for 4200 dollars. Would you recommend ARE? Any other comoon reputable brands?
Old Dec 17, 2016 | 02:13 PM
LS6 is 100% a wet sump
LS7 is some sort of semi dry sump...not worth the hassle IMO.
ARE or Dailey would be the two big names with regards dry sumps
Old Dec 17, 2016 | 02:51 PM
3 window's Avatar
I meant the LS7 system. Sorry for the above.
Old Dec 17, 2016 | 05:35 PM
oscs's Avatar
Batwing C5 oil pan > every other LS wetsump pan
Old Dec 17, 2016 | 05:51 PM
It would probably be the best wet sump setup....but for a proper track car that will see a lot of g's in every direction, it will be no match for a dry sump.
Although it's a damn sight cheaper. It really does depend on how hard it will be going around corners and changing direction etc and of course under braking.
But if the car is built around the wet sump and needs to change later to dry sump, it can be a huge amount of work finding the room for everything and taking it all apart again.
Old Dec 18, 2016 | 09:16 AM
oscs's Avatar
Agreed. But that's why i said all other wetsumps. There's no comparison to dry.
Old Dec 18, 2016 | 10:10 PM
LASTLS1's Avatar
6 Second Club Moderator
I've run 6's at over 200 mph never had a issue with a wet sump. I don't road race though
Old Dec 19, 2016 | 05:42 AM
LS1-IROC's Avatar
C5 batwing would be my choice as long as you don't have sustained high g'2 in one direction for extended periods of time. I worked on the development of that pan many years ago and it is damn capable. I'd opt for the 2 piece design over the one piece if you can find one.
