drive pressure with vsr billet 7875
I can believe 2:1 on my set up. (6.0 with a 222/228 .566/.571 115+2 comp cams with xrpm lobes)
My questions are:
Is this backpressure close to what you guys are seeing on your 7875s?
Would a true "turbo" cam help lower the backpressure?
I'm concerned about choking the motor before I can hit my goal of 750 wheel.
It does spool fast as hell though! Thats nice!
FF86, (what is your name btw?)
Your right, I dont really have enough data. Just enough to make me curious.
as you might expect it spools much faster than the gt45/5.3 set up.
-Adam
I only pulled one plug at 15psi and it looked really good. A little fat maybe but overall pretty good.
Shamefully I'm doing street pulls so I cant really get after it. It's basically a launch on the sloppy brake & line lock. The converter is too tight so it simply annihilates the drag radials as soon as positive pressure builds.
so here's where I think I hurt it.
no knock retard on that pull. The one prior didnt check plugs out yet. I dont think a compression test is worth it, it's puffing out the oil fill cap pretty good.
$16 ebay 0-100. I have an SSI sensor I test them against, they're surprisingly accurate. one thing to note is the accuracy near either edge of their limit is where they lack. if you will be measuring right at 98psi or something, get the 150psi one. does that make sense?
hey stevie, can you help me understand what valve events would do this?
later intake opening? i'm just beginning to open the door on camming turbo cars.
I need to hit the books.
If you had very high backpressure, you'd want the exhaust valve closed to prevent exhaust charge remaining in the cylinder or worse into the intake itself during overlap or intake valve opening.
So no or negative overlap too although obviously events can be played with in various ways
If you were close to 1:1, then it could almost be treated a little like a n/a setup as there should be no huge bias towards reversion.
But 3:1 would be ******* high, so that would probably like shorter durations and negative overlap.
I'm sure some of the cam experts could explain better though
