Has anyone tried the FItech 70050/70051
#361
I was mostly checking to make sure it was not a common problem with Fitech.
The tach I have is an older no-name aftermarket. It didn't hurt my feelings to order the new Speedhut.
#362
I did set it up with the hend held. The tach agrees with the hand held most of the time. Then it either goes to zero or some other reading that doesn't make sense. I think that if, as you say, the Fitech puts out the same signal as stock ecm I can set the Speedhut on 4 cylinder and it should work.
#364
Prob lite it off Wednesday, motor is in the boat, wired, fuel system tested I just haven't had time to do the setup and throw some flame proof vht paint on turbine housings. If your on the fb page for ultimate ls users I'll post idle on gas video this wknd to it , hopefully. The twin quantum 380s are controlled by a Ford style starter relay/solenoid signaled by the fitech pump control wire, gave them 8gauge from battery to feed on �� without any check valves , running 10an from tanks to pumps then split into 8s at back of rail makes instant rail pressure when the pumps come on lol. Of course rail pressure fades off when they shutoff but it should crank up during priming plus I read it runs the pump during cranking. Excited to try it, be the cheapest damn way to fuel with efi on big power
#366
Well no luck trying to start it today ,even took off half the day to play with it but I'm getting no spark at all. All fuses good, rpm counts on handheld like it should, key wire always has voltage even during cranking, 24x reluctor. I know coil sub harnesses are correctly plugged into the right coils etc etc etc
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
#367
Well no luck trying to start it today ,even took off half the day to play with it but I'm getting no spark at all. All fuses good, rpm counts on handheld like it should, key wire always has voltage even during cranking, 24x reluctor. I know coil sub harnesses are correctly plugged into the right coils etc etc etc![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
#369
Another fella from the fb fitech ls page suggested about the same, I loaded the 24x 60e tune then setup again and it fired to life! Died a few seconds later but ive gotta oil leak on turbo inlets to deal with before trying to lite it again. I don't want to burn my shop down now lmao
#370
#372
That's me! Jonathon right?
#373
Well so far the 210s aren't going too well. Fixed the oil leak on lunch break and motor fired up nice, ran maybe 20seconds then went pig rich and died. From then on its flooding while cranking and I've turned the cranking fuel down as far as it'll go(-70%) on all 3 cranking fuel inputs and prime . Literally have to lean it out and let it fire on what it flooded on, throw fuse in while its running kinda deal then it just runs pig *** rich. Base is 44psi on gauge, key on engine off, no intake leaks, dual widebands both showing full rich. Guess I shouldve started with deka 80s
#374
How do you have the injector settings in the fitech? Don’t they only come with 60lb injectors? So you’re running an injector that will need 3.5x less fuel at idle… Can you subtract like 300%? 70% seems like too little maybe?
Wish I was a little more familiar with it. Been trying to get the fitech to connect to a laptop for 2 weeks on a buddies car and they can’t get it to work. Been talking to fitech tech support and all.
#378
#379
They told us the same on gm stock ecu but guys are running 210s in those. If it weren't for knowing the power adder 1200 tbi guys are having good luck, I would throw up my hands and go to diff injectors but they're making them work so I wanna try. I don't need a great idle etc. It's a dragboat but do need it to start and idle lol
#380
Ive tried lowering base to 35, lowering motor size 20% also and nothing has really helped. I'm stuck at going to aus 114lb injectors unless someone can confirm the ability to change injector data in procal beyond what lil the handheld will do for injector size
just as worried that the 114s will be a problem
need at least 1200hp worth of gas injector at 43.5 base so my pumps do the job.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
