what's the secret
Old Jun 2, 2017 | 11:13 AM
  #121
SethU's Avatar
Even a load bearing dyno isn’t going to apply the same types of loads and stresses and actual ¼ ½ etc pass will put on the engine. All dynos are just to get a rough tune, the real world tune always needs to be adjusted from the dyno tune if you want an optimal setup.
I haven't done enough of either, to say with any real authority. But...
It seems to me, that cell-for-cell optimization... or if a tune was taken so far as to do cell-for-cell, individual cylinder trimming, fueling and spark and boost curve optimization... that it would be pretty difficult to achieve a full spectrum of quantitative data while track tuning. It's also difficult to imagine that there would be any room for improvement after that sort of tuning.
However, that's not your average tune session either. That's days and days on an engine dyno, touching and retouching every nook and cranny of a tune.
Track tuning may very well offer benefits over (or in addition to) the average chassis dyno tune with the average tuner.
I just can't see there being anything left on the table after, what I would call, a "proper" dyno tune.. And, just because I can't picture something, certainly doesn't make it so.
Old Jun 2, 2017 | 11:29 AM
  #122
Forcefed86's Avatar
IMO, Even if you tuned each cylinder individually to its peak performing power level on any dyno, All of those “perfect” settings would no longer be perfect in a real world application.
The real world loads applied to it are vastly different. Take that “perfect dyno tuned engine” and run it in the 1/8, ¼, ½, mile, salt falts etc… and each tune will have to be adjusted drastically to perform optimally. Taking in to account vehicle weights, gearing, aerodynamics, atmosphere, etc… But like you say… no one is spending millions of dollars and man hours on a “perfect dyno tuned engine” anyway. Nothing wrong with using a dyno to get a rough tune. But in my experience you always have to adjust the tune quite once you get to a track.
Old Jun 2, 2017 | 11:40 AM
  #123
SethU's Avatar
The guy who is tuning my car has been tuning LS engines forever so when he advises against running more than 12 lbs. on straight 93 pump with a decent A2A I'm inclined to listen.
Just another perspective on this. Not to say it's so or not so. Just something to consider.
Perhaps he's blown one (or more) up at that level. He wouldn't be the first well known and respected professional to blame something and not take personal responsibility in the matter. Not in a bad way, per say. Not outward responsibility. The inward kind that we all avoid from time to time. Admitting to ourselves that we don't know something, that we did something bad or wrong or unintentionally wronged someone. It's a horrible feeling and takes massive character to admit, to ourselves. Not everyone has that massive character, all the time. Speaking from personal experience, avoidance of the matter or blaming something other than me is my knee jerk reaction. I have to purposely and intentionally swallow my pride... if/when I swallow my pride.
Sorry to expand on that for so long. I just don't want it to come across as a slam on the guy. He's human. It's more than likely, that he's speaking from personal experience. What might that experience be? What were the conditions of that experience? Was it truly more boost related than tune related?
The evidence is out there, of what many many others, even non professional hobbiests, have achieved safely.
One thing is for sure. He's not likely to blow your **** up. That's a good thing.
Old Jun 2, 2017 | 11:52 AM
  #124
SethU's Avatar
I'll have to ponder that.
Old Jun 2, 2017 | 12:51 PM
  #125
SLOW SEDAN's Avatar
Originally Posted by svslow
What is the 'hefty investment'? No way I would pay some random guy $500 every time I needed a tune.
x2, they start at $600-650 for a FI tune around here and some shops are cracking people over the head for $900 a pop. Its really sad, I've seen a guy get charged $500 and all they did was tweak the idle for the cam and make it run pig rich.
I agree, dyno gives you a starting point. The distance matters as you say because you can lean on it harder for shorter duration. I agree the load on the dyno vs load at the track is different, making timing and boost curves different. Things like how much will the tires hold, so you throw all the dyno power at it and it spins or wheelies, that doesn't make it faster at the track. Forced air from going 100+MPH vs sitting still on the dyno can change A/F. What about getting the transbrake launch correct or getting shift points dialed in? I don't see that done on a dyno. What if the air is better at the track then in the dyno room? You want to leave the dyno tune in it or take advantage of the good air? What if the guy just wants to go faster to meet a personal best, record, etc and says screw it give it the beans would you rather be stuck with the dyno tune or be able to lean on it harder? Certainly lots of scenarios where a dyno tune can be improved.
Old Jun 2, 2017 | 12:56 PM
  #126
neverstop's Avatar
I'm not an expert tuner, just know enough to make small tweaks so not claiming to be tuning god here but just to back up what ForceFed86 is saying, the tune that worked on the dyno for my 900whp car had serious issues at 1/2 mile and needed adjustments to work properly. The loads of going WOT for 18+ seconds and through every gear in a row and then WOT deep into 5th gear, all consecutively, are very different than a 5 second 4th gear pull on loaded dyno. Not to mention the stress on the fuel system, heat in the fuel and oil, heat in the motor, IATs, intercooler flow, belt issues, etc are all very different at the track then on a dyno.
Maybe at 500whp the differences aren't enough to matter or notice, but imo once you get up to 700-800+ hp setups you really can only make them run well and be reliable by using the dyno as a starting point and tweaking it in actual use for what you do with the car. Your typical $400 dyno tune is not going to be sufficient for a 1000hp car in my experience.
Paying $500 for HP tuners and learning to tweak the WOT timing and fuel is fairly easy too. I think the hard part in tuning is getting all the little stuff to work perfectly for daily driving. The WOT stuff is not nearly as hard. With the disclaimer here that again I do not consider myself an expert on tuning by any measure. Just my $0.02
Old Jun 2, 2017 | 04:23 PM
  #127
stevieturbo's Avatar
Originally Posted by TrendSetter
Curious, why twins?
This ?
Old Jun 2, 2017 | 04:40 PM
  #128
ddnspider's Avatar
Originally Posted by gametech
You make really good points about 1/2 of the tuning issue. If you scale the tune to bypass MAF limits, you have to scale a lot of auto trans tables. For a personal vehicle this may just be another interesting part of tuning, but I can imagine this being very time consuming on a professional level. BTW, I have done 2bar tuning with a fully enabled MAF, and I do prefer it if the build allows for using the MAF. Sometimes, however, this just isn't a practical solution.
dang thread blew up, I'm behind on my reading lol. Just saw this....ill have to look at my current time but I'm pretty sure I only touched a couple a4 tables and have no trans issues, shifts exactly when I tell it to within 100rpms.
For the rest of the posts about tuning on a Dyno vs street and track and DIY.....I'll admit I used to go to a well known tuner for years....Everytime I made a major change it was another 2-600 bucks. I finally got tired of it and took the time to learn how to tune and never looked back. Plus I exclusively tune street and track due to exactly what frcefed talks about above....load for that long and shifting and then pulls in high gear add way more load than a Dyno, even load bearing can do.
Old Jun 2, 2017 | 04:44 PM
  #129
ddnspider's Avatar
This!! Tuning a large cam with a bunch of overlap is way tougher than tuning WOT. Make it a stick and it's even worse.
Old Jun 2, 2017 | 08:21 PM
  #130
Black_Sunshine_99's Avatar
Perhaps he's blown one (or more) up at that level. He wouldn't be the first well know and respected professional to blame something and not take personal responsibility in the matter. Not in a bad way, per say. Not outward responsibility. The inward kind that we all avoid from time to time. Admitting to ourselves that we don't know something, that we did something bad or wrong or unintentionally wronged someone. It's a horrible feeling and takes massive character to admit, to ourselves. Not everyone has that massive character, all the time. Speaking from personal experience, avoidance of the matter or blaming something other than me is my knee jerk reaction. I have to purposely and intentionally swallow my pride... if/when I swallow my pride.
Sorry to expand on that for so long. I just don't want it to come across as a slam on the guy. He's human. It is more than likely, that he's speaking from personal experience. What might that experience be? What were the conditions of that experience? Was it truly more boost related than tune related?
Well said SethU and totally agree and to me that's okay.
Old Jun 2, 2017 | 08:31 PM
  #131
For me the heavy investment is the HP Tuners $600 / the laptop needed to use it $1,000 / again the time I don't have and the fuel spent driving around to actually tune the car.
I paid my tuner once $300 and he's a great enough guy he lets me come back and make changes without charging me so the $500 every visit doesn't apply to me luckily.
I've got maybe $2,500 in this setup start to finish over three years so I've gotta stretch my dollars and utilize them effectively and carefully right down to how much insurance and fuel I can use for the summer.
I'm attempting Champagne horsepower on an orange juice budget lmao.
Old Jun 2, 2017 | 08:36 PM
  #132
If I may ask, I'd love to start tuning myself and I really do value everyone's opinion who has chimed in on this regardless of which side of the fence you're on so thank you guys.
With that being said are there a particular book you guys would recommend to read that can cover all the basics?
It needs to be a book so I can read it on the *******, its my only alone time lol.
Old Jun 2, 2017 | 09:41 PM
  #133
sbcgenII's Avatar
dang thread blew up, I'm behind on my reading lol. Just saw this....ill have to look at my current time but I'm pretty sure I only touched a couple a4 tables and have no trans issues, shifts exactly whsssen I
That is because you have a 4l60e. Switch to a 6l80e and all the shifts are based off calculated engine torque.
Old Jun 3, 2017 | 01:00 AM
  #134
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Says the man who has never had access to a proper load bearing dyno in a climate controlled environment. I fully agree with you in most cases, because few people have access to, or know how to use a dynamometer. With a proper setup, you DO NOT just do a full throttle pull and call it a day. You have the ability to adjust the load from the bare rollers (which should be much lighter than the car), to an amount equal to towing a huge trailer. You also have the ability to hold steady rpms at any load in any cell you wish. This is in conjunction with being able to vary intercooler temps and intake air speed at will. The idea that you can get a better tune at the track is predicated on the idea that you don't have access to proper tuning equipment. Sadly enough, this idea is usually correct.
Old Jun 3, 2017 | 07:27 AM
  #135
ddnspider's Avatar
theres plenty of good info and tutorials on HPT forums and EFI Live forums, but my favorite is Greg banish's DVDs. Picture is worth a thousand words....but an hour long video actually watching someone go through the process of tuning is awesome. It really cleared some stuff up for me early on about what order to do stuff in and why.
Old Jun 3, 2017 | 07:30 AM
  #136
ddnspider's Avatar
That sounds reasonable, but if you're going through the trouble of scaling all the engine tables, doing it to the trans tables doesn't take that much longer. Considering you can do it sitting on the couch before you ever start actually logging and making changes, it's pretty easy. One hint that ive noticed though is even when scaling the tune, I usually don't scale the idle tables, if I do it doesn't want to hold idle very well. I've heard of a few others with the same experience.
Old Jun 3, 2017 | 08:22 PM
  #137
TrendSetter's Avatar
efilive doesnt require a laptop.
tuning is nice because its the only thing i can do to work on my cars without getting dirty.
and if you think efilive or hpt is tough, try tuning one of these shitbox imports that are community reverse engineered. its insane how complicated it gets, and a lot of it nobody really knows for sure what the tables do.
Old Jun 4, 2017 | 03:02 AM
  #138
Blown06's Avatar
8 Second Truck Club
I have never been on a dyno, and probably wont anytime soon. What are your thoughts on using fuel pressure, ipw and AFR (basically fuel consumption) as an indicator for peak torque/peak ve?
as for the evo boost taper, it is a limitation of the internal wastegate design that they use and i think those curves are so ingrained in the community that they tend to tune in that curve even when moving to externally gated standalone stuff. or im completely misinterpreting the whole thing. Im a foreigner in the mitsu world.
I use this very strategy, especially to get me in the ball park quick and avoiding issues quickly. I mainly tune only Holley EFI these days and the Fuel table is set up to dial fueling in using Fuel flow in lbs/hr. There is a button that allows you to see the fueling table in the "traditional V/E configuration". I'll do that and overlay a pass. It will show me what at what engine rpm and Manifold press where the V/E. numbers are highest. It has been discussed plenty and you can pretty much use this method to see where the engine is making peak torque. This allows you to pull timing in those areas to keep the thing safe.
Originally Posted by mOtOrHeAd MiKe;19636861[COLOR="red"
]Funny how many top "tooners" only write FI tunes in SD - I believe that just goes to prove just how incapable they are.[/COLOR] I am running the same LS7 MAF/4" tube/Saxon PC screen in a blow-through configuration in our Procharged stock long block LS2 TBSS. I am pretty certain most everyone has an opinion on how "wrong" that was. Oh well, it went 11s at 5200+lbs.
The 9/10ths solution is plenty for anyone not seeking to be an internet hero. Everyone likes to feel validated for their achievements, sure - sometimes the greatest validation is always being out in your car, not in the garage fixing it.
To OP's question: Manage your IATs, AFR, and timing wisely - especially at MBT. You must creep up on the number that works best for your combo, not just assume that pulling a tune from the internetz and letting it eat is going to be enough out of the gate. There is no one size fits all solution. DA also has an impact that is a variable that you cannot plan for (hence 9/10ths leave some room for error).
I would also add that reducing the load on the engine (weight of the car, reciprocating mass, etc) is going to ease the strain when pushing the limits of pump gas.
Statement in red is pretty moronic and pretty much immediately disqualifies you as being able to contribute usable advice in this thread. Sorry bro, but you missed it.
Old Jun 4, 2017 | 03:27 AM
  #139
Blown06's Avatar
8 Second Truck Club
I'll add to the above post a little food for thought on Centri blower set ups vs. turbos.
Typcially, turbo cars reach their total boost at a much lower rpm than a centri blower. Because of this, really hot centri cars sometimes don't even make a peak torque number. Especially ones that are "ratio'd" in a fashion where boost is climbing all the way to your redline/shift points. My truck is a pretty good example of that. I run an F2 and the few times when I made passes around 26 psi, you just don't see the V/E numbers falling by the shift point.
What I'm getting at hear is that tuning for safety/reliability is completely different from a turbo car to a centri car.
Old Jun 4, 2017 | 06:47 AM
  #140
ddnspider's Avatar
i agree with that. I made a thread awhile back looking for input on tuning a centri car and got crickets for a response.
