What made you switch from procharger to turbo?
#61
Ya a lot more... over double actually! 317's, studs, and LS9 gaskets have held in 35+.
Some people seem to be overly concerned about MPG when you mention a TH400. But why you want to make good power and be concerned with MPG I have no idea. People spend a ton to make a 4L80 work because they are concerned with MPG. I took out my 6L80 and replaced it with a TH400 and highway MPG might have changed 2 MPG. I still got 18-20MPG cruising with the TH400 on E85 which was good enough for me. The 4L80 costs over $2k more for a similar build, its going to take a long time to get that $2k back 2MPG at a time.
If if I could make 700 rwhp NA and be streetable I would. I doubt that can happen so it's either procharger or turbo. Speed inc has done most of my work and all my tuning over the years so I'll work out the details with them since my mind is pretty set on the procharger now.
#62
The car isn't a daily driver so I'm not concerned with mpg. I prefer to keep the 4l60e if possible, but if it doesn't hold up I'll go from there. I do like cruising on the highway at a lower rpm so I like my overdrive for that reason. With stock gears trapping 135 mph I was shifting into overdrive right at the end of the quarter mile. That worked out perfect, but if I trapped higher I'd have to run a taller tire or taller gear.
#63
I would build tranny before ever putting a kit on. A kit with stock tranny is pointless. Also 7 psi on a procharger kit runs like ****. I've done it twice and the power sucked. An LS2 will run fine at 10psi. I ran my 90k ls1 motor on 10 psi with no problems... Doing the low boost to make things survive method sucks...
#64
I'm considering going the procharger route on my GTO over this fall/winter. I've done a bunch of reading on the subject and it seems common for people that start out with a procharger to eventually end up switching to a turbo. I'm curious about some of the reasons for this.
#65
If it were me I would mod it the right way so you arent taking everything out twice. Put a TMS 370 in it with a decent boost cam and a built tranny. This will be a good gain in power you can have before you get the procharger kit. Then while you save for that you can have a badass motor and trans in the car and see what it runs like that. And when you get the procharger on you can see what your gains are again. Putting the blower on and then taking it back off and redoing it all when you put the new motor in will suck.
You might be surprised what 500-600NA horsepower will do. Head/cam LS7's dyno mid 600's all the time. I had a LSX454 after having a blower and the NA throttle response **** on it. I ran 11.3 in a 4000lb car with the stock 6.0 putting out only 425hp, being lighter even 500hp would have you deep in the 10's. I don't know what your MPH/ET goal is but with your budget you can build a really nice NA engine to run deep 10's and give it the jug on race days to run single digits without any of the hassle of blower or turbos.
#66
If you are wanting the power now. Just build the one thing that is guaranteed to break with any kind of power the 4l60e... The ls2 will handle 600rwhp all day on a decent tune.. Put a built tranny in. If going 4l60e then don't waist your time and go with the absolute hands down best RPM TRANSMISSIONS.. Do a built tranny and d1sc kit with a 10psi pulley and go make some good power...
#67
Ok I've been paying attention...and here is what I've learned in this thread...
Don't put a blower on a stock motor because you will just have to pull it off when you replace the motor.
Don't put a blower or built motor in the car until you put a Th400 in it because anything else is a waste of money.
Don't do any of that until the rear end is built.
Don't put a supercharger on the car at all because you will replace it within two years with a turbo.
I just bought the car about 3 months ago. With the price of the car, cam, headers, converter, rear suspension, wheels, and tires I've got 20g in it in 3 months, which isn't too bad. I plan to spend another 20g on it this winter. That is not enough to put a custom turbo, built motor, built th400, built rear end, and fuel system in it. So it looks like I will do nothing at all and wait until the following winter after this coming one when I have 30 to 40g to spend.
If only we could all start off with a perfectly built 1000+ rwhp car that nothing will ever break or need to be replaced again...lol...we all know everything can break and eventually will. We also know very few of us can afford to buy a car and replace every single thing and make over 1000 rwhp in the first year of ownership. Some people here can and those are the guys I like watching not trying to compete with because I can't! At the same time I root for them as they compete with the best "street" cars in the country.
So maybe forced induction is the wrong choice for me or I'm better off building a stroker motor, trans, and rear this winter while staying NA until the following year then adding boost. E85 is an option if I wanted to run 11 to 1 NA for a year or I could run 10 to 1 and still boost it with 93 plus meth.
Back to the drawing board I guess...LOL.
#68
I agree its like blowers need 10psi to make up for the weight and crank drag and don't wakeup until 13psi.
That doesn't seem right at all, either you aren't revving it out or running a tiny tire. 28 tire and 3.45's should have you crossing at 155mph depending on converter slip.
#69
#70
I don't see why you need a built engine as the Gen4 bottom ends handle a lot of power. Run the stock engine until it gives up smoke... probably last longer then you think.
A $1500 TH400 will more then support what you are doing. The rears in those cars are weak though so whatever you can do to fix that after it breaks plan for it. But again I wouldn't bother until it breaks.
Fuel system is easy and even doing it fancy is $1000.
But I don't see anything that can possibly add up to $30-40k? Jesus with $30-40k I wouldn't even know where to start. Actually ya I do, I'd be using the same clapped out 5.3 and homegrown turbo kit I have now and slap the other $37k in the bank! But if you really want to spend money your budget would allow for an LSX block, Shearer Fab hotside, and a Precision PT118!
#71
Yea I agree you have some crazy numbers. If your just smart about and spend A LOT more time researching you should be able to completely build the car for much much less. Learning to work on the car yourself will save you a TON of $. It can be a bitch some times, but being able to say you built it yourself is all worth it.. With boost you don't have to spend a crazy amount of $ on an engine. A basic forged 5.3-5.7 will have you easily 800+rwhp capable. I have a forged iron 5.7 on mine and it will be going 9's soon... I have much less then 40k invested in my car..
#72
You shifting at 6k RPM? haha Sounds like you needs a trans tune!
Do you have fancy $10k wheels? Aint no way a cam swap and boltons add up to $20k otherwise. You certainly don't need to spend $20k to go turbo. Heck most people I know don't even spend $5k.
The 20g I spent on my new car includes the price of the car itself which I just bought 3 months ago.
The point I was trying to make in my previous post is...we all start some where we can't all just start with the perfect setup with the our dream amount of power right from the beginning. Some can, but those are usually guys competing with the fastest radial cars in the country not guys asking questions on an internet forum.
There were several guys that said putting a blower on a stock motor is a waste because you will just have to pull it off when you build the motor anyway. There were several guys that said 10 psi on a stock motor sucks it makes **** for power.
The thing is 500 rwhp at 8 psi is better than the 390 rwhp I make now cam only. So while that is **** power to most of you it's a step forward for me and might get a high 10 out of it in a GTO. I would definatley want a solid trans at that time as I wouldn't expect the stock 4l60e to hold up to 500 rwhp for long. I would build the rear at the same time along with driveshaft, half shafts, CV's, and stubs. The rear suspension is already done. When I can build the motor I could up the boost with the same supercharger and get near 700 rwhp. Then if a few years later I want more I sell the supercharger and go turbo.
We always want more no matter what we have. So the point is I can do this in a couple steps and while it will cost a little more if I plan carefully I can minimize wasted cash while still reaching my goal of 700 rwhp within a year and a half or two.
Do we tell everyone that wants to put a cam in their stock motor don't do it you're just wasting money. Wait until you can build the motor, trans, rear, and put a custom fabricated turbo on it so you don't waste money redoing anything? Hell no we say yes cam it!
All this assumes I would address the fuel system at the same time to handle my final goal plus a little more so I have room to grow.
#73
I can install a trans, but I'm not going to attempt to build the trans myself. I can install a differential, but I've never rebuilt a diff. So I could probably install a procharger, trans, and the rear end parts then take it to have it tuned.
I obviously have a lot to think about to spend my money wisely. That is why I'm planning now for something that will not start until this November.
#74
Procharger d1scx kit - 8k
Level 6 Rpm trans- $3200
Built rear- $5k
TMS mighty mouse forged 5.7- $5300
Siemens 60lb injectors- $250
Racetronix dual pumps + wiring- $400
That is a 100% built car ready for the 9's at 700+rwhp for about 20k that doesn't include all the $ you can get back from selling stock parts.
Sell your engine-$1500
Sell rear end parsk-$500
So after that your under 20k for a completely built car
Built rear- $5k
#77
I bought a really old house cheap in 2004 on a 15 year loan and fixed it up slowly over time to where I'm happy with it. My daily driver is a Ford focus with a salvage title I bought for $4000 it only has 60,000 miles on it. I don't go on vacations and have perfect attendance for 18 consecutive years at my job. I've been living cheap for a long time and never had kids so this year I decided I wanted to buy a car and now I'm blowing all my savings LOL. I still have my retirement account and have another 25 years or so to work before retirement so it's time to play because you only live once.
#78
...and you are probably faster than I'll ever be...LOL...I've always liked Pontiac and I really like these GTO's even though they aren't real Pontiacs and they are very difficult to make fast with their IRS, tire size limitations, and weight.
#79
OP, it sounds like you need to sit down with a pen and paper (if you're old school like me) and write down your goals. Then research and write down the kits / parts that will get you there with the part prices. Hop on the computer again and write down shops / vendors who sell, install, tune the stuff you're looking at. Call and e-mail them telling them your goals and budget. Message people on here who have done what you're looking at. Narrow it down to whatever best fits your goal / budget / skill level / etc and start punishing your checking account.
Vengeance, Brute Speed, Race Proven Motorsports, Livernois, and many others are LS1tech vendors / sponsors who have dealt with your ride and can answer questions and provide sales and service. There are plenty of site sponsors and non sponsors who have built and tuned high HP or 9 second GTO's with TVS 2300's, Prochargers, Vortechs, Paxtons, Turbos. There are people on this forum who have been there and done that. You can message inquiring about their setups and leverage all of that knowledge.
#80
