Project Hairy Banana (1967 Camaro single turbo)
#661
Yeah I think for most of '21 I'll run these 15x12s with 28s and 29s, but I have been thinking about getting some 15x14s or even 15x15s which would give me the ability to run something that sits out a little better. Longer term I might dig into what it would take to 4 link the car and then I'd just start with a new housing.
The following 3 users liked this post by Pro Stock John:
#663
For some reason my radiator wiring got hot, so we are redoing that. If snow holds off we'll do some street tuning, though I still plan to take the car to Jon Capizzi for the WOT tune.
The following users liked this post:
Project GatTagO (12-31-2020)
#666
1967 Camaro LS 5.3 Single Turbo
Been working on this for 2.5 years, finally buttoning everything up. Details:
1967 Camaro, former BBC + 8-71, full tubs, can fit 15x15s
5.3 gen 3, SBE but building an LC9 with Fast Times Motorworks
799 heads for now
Holley Hi Ram
Baking Engineering turbo cam (Capizzi #1 style)
Truck manifolds, v banded and lengthened
FI BW S485/96 1.32 billet wheel
4" down pipe, added Vibrant muffler
Holley Dominator computer system
Holley Dash
Holley 160 lb injectors
Holley fuel pressure regulator
Holley Earls Ultrapro PTFE AN fittings and hose
Bosch 044 fuel pump for cruising
Weldon 2345A fuel pump for boost
E85 fuel, will add flex fuel sensor
Summit Racing radiator
Ford Contour radiator fan
TH400
9", upgraded the guts to Quick Performance 40 spline axles and spool
Strange brakes all 4 corners
BMR front upper and lower control arms
Alston ladder bars
Kirkey drag seats
B&M Pro Ratchet shifter
Glasstek 5" Sunoco hood, bolt on
Glasstek trunk lid, bolt on
Sanders 15x4 fronts, MT SR Sportsmans
Sanders 15x12 rears, MT Pro Brackets but probably going to 295 tire
Viking double adjustable front shocks
Strange single adjustable rears, probably temporary
... Ready for tuning, has a rough tune in it now.
799 heads for now
Holley Hi Ram
Holley Dash
TH400
Alston ladder bars
Kirkey drag seats
#672
#674
Little updates:
I'm re-wiring my radiator fan, wire got hot. I have a Leash relay sitting around, using that for now. My Contour fan pulls a lot of power on start up.
I lined up another buddy to work on some driveability, he's going thru my tune now. Fingers crossed Chicago doesn't get any snow next couple of days so I can drive it some more.
Really happy how complete the car is now.
The following 2 users liked this post by Pro Stock John:
Project GatTagO (12-31-2020), The BallSS (01-04-2021)
#675
I'd like to go mid 8s in 2021, with 7.99 potential. The cam, turbo and most other choices are patterned on Jon Capizzi's 7.7@174 build, I bought his old turbo and got a copy of his first cam. He was 2900, and I might be 3100 to start.
By the way, my car had a rough tune in it, and it needed a lot of work. I hired Andrew aka GotTaGt to do remote tuning and he did a killer job. Start up, idle, car is really good now. We'll get back at when the Chicago roads get cleared of salt.
In the meantime, I will continue to clean up wiring.
I will also spend a bunch of time air bleeding the cooling system.
Project GatTagO (12-31-2020), rkupon1 (02-16-2021)
#678
Update.
I rewired the radiator fan and then Andrew aka GatTagO started to remote tune my car. Worked out great, got the cold start, idle and lower RPM stuff working great!!
I'm redoing my lower radiator hose, and then will take my time to bleed the cooling system.
Our roads are salted, so will be a while before the '67 gets on the road, but will be ready and waiting for that moment!!
#679
After re-reading Rye's build thread I feel like I"m not going into enough detail lol, so here goes.
So I'm about 2.5 years on a pretty substantial redo of a former pro street car. Bought it running, parted it out the driveline in the first 48 hours of ownership. I already had the 8-71 and engine sold as a package, got good money for those.
Since the roller arrived at my garage, I've redone the following:
- Drag brakes, new brake lines, new master cylinder
- New front A arms, front Viking double adjustable shocks
- My buddy with the shop installed prior the 5.3 which has a Baker Engineering turbo cam (Capizzi #1), 233/236. Also did trunnion mod to the rockers. He also installed the TH400 and welded up the turbo kit
- Wired in a Holley Dominator + factory harness. Still picking at some aspects of it, but the car has 95% of everything wired up
- Swapped in B&M rachet shifter
- Swapped in Holley screen
- Plumbed in C02 system
- Fixed rust issue under windshield, had to bring car to a buddy, big detour
- Pulled rearend out, had 31 spline axles and posi. Swapped internals, now has 40 spline Quick Performance axles and spool
- Plumbed trans cooler + fan, has an air gap, it's under the passenger side seat
- Swapped out old seats, swapped in Kirkeys + a bracket for the driver's seat to attaches to roll bar
- Swapped fuel cell, and built system. Has 15 gallon plastic cell, two pumps, one is a Bosch 044 and the other is a Weldon 2345A. The plan is the Bosch handles low HP street duties, and the Weldon comes on with a few lbs of boost. Car is set to run on E85, but plan to plumb in a flex sensor
- Swapped trunk lid to fiberglass unit from a buddy
- The buddy who fixed the rust also installed my hood and installed the Aerocatch hood latches. Lot more work than meets the eye
- Ordered and installed Sanders wheels, 15x3.5 front and 15x12 in the rear. The rears are 1.5 backspace.
- Get off my *** and swap out lower radiator hose that is a straight shot to the radiator, then bleed the system. When we last ran the car it got hot, probably has a lot of air in there, system has never really been bled
- Then Andrew B can get back into the Dominator and assuming I have clean roads we'll work together to finish editing the operating tables.
- I need to pick into my config for the big pump (Weldon 2345a), Andrew didn't see it in the tune but I think we just need to set up the entry in the Dominator, that pump is all wired up
- After all that, make some boost hits in a local parking lot
- After that, I need to swap out my ladder bars, current ones are pro street style, have poly rod ends. I have another set to swap in that will have solid ends in back and heims up front. I'll have to source and figure out some shims since the ends are smaller.
- Allignment
- Drive it a lot, make sure it's 100% good
- Track passes
