Project Hairy Banana (1967 Camaro single turbo)
Old 07-09-2021, 07:03 PM
  #941
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,181 Likes on 765 Posts
Thanks for those positive waves.
Yeah I'm wanting the car to be truly 100% before I hit the track. My next video will probably be a rolling shot of me getting on it.
The following 2 users liked this post by Pro Stock John:
cam (07-12-2021), G Atsma (07-09-2021)
Old 07-16-2021, 06:35 PM
  #942
LS1Tech Co-Founder
Originally Posted by 3 window
I run Purolator or Wix.
PL14006 Purolator New Oil?
Old 07-16-2021, 07:59 PM
  #943
3 window's Avatar
That’s the Brand, but I run a CTSV pan that has a bigger thread than the typical LS pan.
Old 07-16-2021, 09:21 PM
  #944
LS1Tech Co-Founder
Okay I'm running a Holley 302-2 pan, I'll research.
Old 07-17-2021, 09:20 AM
  #945
spray280's Avatar
Wix 57060 is listed on the Holley site for the 302-2 pan
Old 07-18-2021, 08:39 PM
  #946
LS1Tech Co-Founder
Yeah so drove the Banana for about 75 minutes today. Good news, it ran, had good driveability.
The bad, first it ran on the warm side, and then I popped/burned the fuse (50A) for my Taurus / Contour fan. Now I'm told I could config my screen to show 'Fan On" so that's something I need to do. Looking back I'm not sure the fan was working for a bunch of the time. My buddy Gary was nearby and came over to me with a a correct fuse (J case for this Leash relay), and some wiring tools. Long story short he ended up rigging the power wire to the back of the alternator so I could drive the 4 miles home. On this drive home it was sitting at 214 most of the time, would creep up a little at lights.
So the plan is to 1. check idle and cruise timing with Andrew B the tuner, and I'm watching @ryeguy2006a 's swap over to a PWM C7 fan.
Anyway once we fix the cooling system I'd have no concern driving this car 30-40 miles.
IO
spray280 (07-19-2021), The BallSS (07-19-2021)
Old 07-19-2021, 09:03 PM
  #947
LS1Tech Co-Founder
Update. I talked to a friend of mine who wires performance cars as a full time job and he's going to take the car in next week and go over all the wiring. I can admit that I don't know anywhere near enough about wiring to be troubleshooting that part of the build. He'll have it 1-1.5 weeks.
Old 07-19-2021, 09:38 PM
  #948
3 window's Avatar
Keep in mind that the dash showing “fan on” only means it sent the signal to the relay. Doesn’t mean the fan is actually operating. You should be able to hear the fan running. If you can’t, your car’s too loud and doesn’t qualify as a street car! Lol. Just kiddin. Hell, for the time being, tie a ribbon or something to the intake or a place you can seen through the back of the hood while driving, then you’d know the fan actually blowing. Blowing a 50amp fuse would be concerning, so having the car looked at is a great idea. I wouldn’t go changing anything yet (fans), you haven’t given this setup a a chance. Wait until you’ve tried everything and you’re still not happy. It’s been super muggy in our area, so temps are gonna be up a little. I was 10° hotter than usual this evening cruising around.
The following users liked this post:
The BallSS (07-21-2021)
Old 07-20-2021, 12:34 AM
  #949
LS1Tech Co-Founder
LOL I can't actually hear the fan to be honest lol.
We might keep the current fan, see what he says. He's wired a bunch of cars and one of them is a 70ish Nova with an LS and single turbo. They been running a Cruze single fan with good results, wired up as simple / off not PWM.
I'm tired of farting around on this wiring stuff.
Old 07-21-2021, 11:02 AM
  #950
The BallSS's Avatar
It could be something as simple as under sized wiring or poorly located power/ground.
When I rewired my dual fans for a three relay setup and oversized the power feed and grounds, it made quite a difference in how the car ran and cooled.
Old 07-21-2021, 11:43 AM
  #951
LS1Tech Co-Founder
Yeah it could just be the ground is not ideal, or the power wire needs to be thicker but I have a lot of money tied up in the car. Jay reached out and he's wired a lot of cars and I want him to fix 1-2 things but look over everything. He'd have the car a week, week and a half.
Old 07-25-2021, 03:11 PM
  #952
cam
cam's Avatar
Bummer re the wiring issue, hope this dude you sent it to does ya right. Man if you were closer id be there in a hearbeat to help ya sort this out. Such is life these days, we all so far away lol
Old 07-25-2021, 08:38 PM
  #953
LS1Tech Co-Founder
I trust him a lot, he's wired 8-9 cars that I personally know, and some of them have run Summit Drag Week.
He has a buddy with a single turbo / LS 1970 Nova and that build is very similar to mine. They drove around for 4 days in the car between Norwalk and Indy. I want that reliability. I know he can do it, and it's taking me too damn long to get there. I'm satisfied with all the other stuff that I did on the car at home (fuel system, shocks, shifter, seats, the wiring, brakes + lines, re did the guts of the rear end, plumbed boost lines list goes on). But trouble shooting the wiring pretty much requires that someone who is very solid with it be there at the car for a day or 3.
Old 07-27-2021, 01:50 PM
  #954
LS1Tech Co-Founder
Jay Blanchard, JayWire Solutions in Wester MI has the car.
First progress pic!
Old 08-03-2021, 04:27 PM
  #955
LS1Tech Co-Founder
Jay did his thing (review and fix wiring, fix cooling system). Car will head back to me in next couple of days.
The following 3 users liked this post by Pro Stock John:
BCNUL8R (08-03-2021), randeez (08-04-2021), The BallSS (08-03-2021)
Old 08-03-2021, 04:44 PM
  #956
The BallSS's Avatar
So what did he end up doing?
Old 08-03-2021, 04:45 PM
  #957
LS1Tech Co-Founder
Did a lot of work on the cooling system, and then went over the wiring. For the wiring, he redid some stuff, I'll have a list.
Old 08-03-2021, 04:52 PM
  #958
The BallSS's Avatar
Excited to hear its running cooler so you can get out and enjoy the car more.
Old 08-03-2021, 05:00 PM
  #959
LS1Tech Co-Founder
Yeah me too.
Old 08-03-2021, 05:03 PM
  #960
The BallSS's Avatar
I feel like your car needs a wing, the back needs some action.
Quick Reply: Project Hairy Banana (1967 Camaro single turbo)
