Dyno day! 8/31/18 99 ws6 twin vs 3582 billet and 80e/8.8 swap - 11.4@126
Old 01-26-2018, 10:55 AM
  #181
Cwarta's Avatar
Originally Posted by MM98
I might have overlooked it but, what size is the AR on the turbines, .80?
They are .82!
Old 01-26-2018, 11:02 AM
  #182
MM98's Avatar
Originally Posted by Cwarta
They are .82!
Thanks man. Because of your thread I just sold my single set-up & Im looking for some gt3582's on ebay. Wife hates me..........Dont care!
Old 01-26-2018, 11:03 AM
  #183
Cwarta's Avatar
Haha! Hell yea, make sure to make a build thread! I'd like to see some more results!!
Old 01-26-2018, 12:12 PM
  #184
MM98's Avatar
Will do! Quick question, I see alot of these lil turbos have provisions for water cooling. I dont plan on using them, what are you plugging the ports with?
Old 01-26-2018, 12:18 PM
  #185
Cwarta's Avatar
They aren't open to any moving parts or bearings, so honestly I wasn't planning on doing anything with them lol. Maybe I should?
  #186
Cwarta's Avatar
It looks like most of the eBay stuff is advertised as gt3582 but the specs are quite a bit smaller, so be careful of that
Old 01-26-2018, 12:41 PM
  #187
MM98's Avatar
Im looking at two of these:
https://www.ebay.com/itm/Universal-P...QAAOSwstJZQOr8
Old 01-26-2018, 12:47 PM
  #188
Cwarta's Avatar
Hmm, recommends not passing 21#, that seems shady for such a small turbo meant for high pressure small engines? For the $75 difference I would be looking at VS billet version of that turbo. The biggest thing that worries me is that I've seen a lot of complaints of the turbos not matching the advertised specs
Old 01-26-2018, 01:40 PM
  #189
MM98's Avatar
I will keep my fingers crossed then, but wont be running any more than 15lbs. Still using the factory 98 ecm with a 2 bar OS & have no desire to swap to the newer ecm & 3 bar at the moment.
Old 01-26-2018, 01:48 PM
  #190
Cwarta's Avatar
Actually I just remembered the non billets are $200 from VS, billets are $300. So it's more expensive on eBay and no warranty lol
Old 01-26-2018, 01:49 PM
  #191
Cwarta's Avatar
Looks like the s475 made good power, I'd really like to try and break 1000 with the biker s480 on my nova
Old 01-26-2018, 08:51 PM
  #192
adamantium's Avatar
Hmm, never considered that? How can they grind me a cam that's bigger than factory, using a stock core?
Thank you!!
Mounted my 2 step box, ran my solenoid wires and did all my plumbing to my dome side of the gates for the boost controller, just need to run my compressed air source feed to the trunk and install my compressor and tank. Got my Viking DA rear shocks installed. Was a tough battle not to take it for a drive today. But it needs more work before I'm happy enough to do that.
[IMG]https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/720x1280/80-image_f350a84f93aaae4c99c87271517373efccad8cd1.jpe g[/I
[IMG]https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/80-image_9d2764695fb3e9fff9c821e30ba01fd1d79fa2dc.jpe g[/IM
http://www.deltacam.com/
Check em out they did my buddies h-series honda motor like 8 years ago and the motor ran strong. I dont remember how they grind the stock cam to get the desired duration and stuff but i think the grind in between the lobes? Not too sure.
Check out this thread someone did it with there lt1 stock cam for $50 lol
https://ls1tech.com/forums/lt1-lt4-m...-cam-50-a.html
Old 01-26-2018, 08:55 PM
  #193
adamantium's Avatar
Thank you!!
https://ls1tech.com/forums/northwest...camshafts.html
I think on the FB sloppy page guys have posted about it usually runs from $50-130 ish
Old 01-26-2018, 10:18 PM
  #194
Cwarta's Avatar
I'll look into it, now I'm curious how they could do it lol
  #195
The Cartel's Avatar
I will admit i've never understood that. Looking forward to the how and why
Old 01-27-2018, 10:23 AM
  #196
Cwarta's Avatar
Would ya just look at it?
Old 01-27-2018, 11:04 AM
  #197
The Cartel's Avatar
it looks better without that damn hood lol! Wheels are **** tho
Old 01-27-2018, 07:41 PM
  #198
jordoza's Avatar
They grind the base circle smaller which makes the lift portion higher lift then grind th spec you want in to it. It would for sure require different pushrod length. So adding that in is it worth it.
Old 01-27-2018, 08:52 PM
  #199
Cwarta's Avatar
Makes complete sense, but I think I'll hold off for an FTi cam. That's pretty much all I will run
Old 01-31-2018, 10:31 AM
  #200
Cwarta's Avatar
Looking at a getting the dlg dual wideband setup from innovate, as well as a fuel pressure guage from glowshift. I just can't hack the cost of an automater at 200+.
Quick Reply: Dyno day! 8/31/18 99 ws6 twin vs 3582 billet and 80e/8.8 swap - 11.4@126
