what's the limit of my fuel system?
New goal is to go 150s, at what point do I have to upgrade the rails. and how much more fuel flow would I need to get there. looks like the bosch 044 flow about 260-300lph at 4bar, I'm thinking about replacing the stock intank, with a 450, and let it ride. another option is replace the 044 with a Magnafuel 4303, thoughts
Factory rails are fine IMO. Been 160+ on them @ 3100lbs Buddies been 172... @ 3300lbs. Both on E70ish.
4303 is a great pump, it’s what I run. (they are loud bastards though) With a 450 in parallel you should be fine and could kick on the 4303 in boost.
Could also do dual AEM 380’s instead of a 4303. They are cheaper and on paper would pump more fuel than a 4303. (not sure they are as robust of a pump though) I have an AEM380 on one of my cars and its makes all kinds of odd noises at random times. So far it’s always held up but I’ve only got 3k on it or so. (also blast it with 18v).
Have you considered a surge tank setup? You could fill it with your current factory pump so you wouldn’t need to replace it. Then run 2 AEM 380’s or a 4303 off the surge tank to the rail. You can run the return and regulator right off the surge tank and have a single -8 up to the front with no return.
Aus $$
https://www.aftermarketindustries.co...ge-tank-sp1200
https://www.aftermarketindustries.co...e-tank-spr1000
US $$
https://www.maperformance.com/produc...-pumps-20-0058
Although with either approach, once you exceed fuel supply of the OEM pump, the surge tank will start to empty. Not a problem for drag use really as runs are so short. But for anything that seen high power use for extended periods the lift pump needs to have a good supply too.
People manage to fit turbos and all sorts front or rear, so there has to be room for a little surge tank, and again keeping in-tank pumps makes it all much more compact.
Or if range wasnt an issue, perhaps lose one side of the dual tank setup and fabricate a custom tank instead ?
Or retain 2 tanks, and again fab a custom primary tank with inbuilt surge tank
seems to be the path of least resistance also. this is an a/c street car with leather and full exhaust. only non intrusive place I can think of for a surge is within the rear bumper. I'll bust out the measuring tape
Can the tanks not be modified for a pair of internal pumps ? That would be cheapest and neatest option, pair of 450's inside
