My first single turbo build
normal weight of 3500
+100 for iron block
-50-70 estimated for cheap drag wheels
+30 for 12 bolt rear
+100 for huge speaker box and stereo sytem he refused to remove
+280 ish for him
50= lbsroll cage
so 4,060lbs minus wheel weight equals 3990lbs
we had the sonnax shafts and drum in his (and a bunch of other crap that i have too) he made 750 to the tire and IIRC was trapping 142-145 at the time. 9.xx i think he got down to like 9.20ish. he broke the 12 bolt as much or more than the trans. hell, the turbo 400 he put in broke the first time in a shorter time than the 4l60. The 4l60 would last almost a year (bout 10 months on average) before we had something break. It was usually a planet that would break. The sonnax shafts held it, my car isnt near as violent as his was and his was alot faster. we almost put the sonnax 6 pinion carrier in but he was tired of putting money in it and the car kept getting faster and faster. it was a car he drove alot at the time and he abused it. he lived a few minutes from me and i'd hear him making hits on the back road a good bit.
with that being said, one part of me wants to do a 4l80 and be done with it. But the other part of me has not much drive or energy at this point to do all that needs to be done to made it work, nor do i have the funds right now. I also dont want the car down for a long time. So as of right now, it think my decision is i'm going to fix this junk and go back with it and maybe next year (my wife is supposed to be taking a higher paying job next year which will take a bit of financial burden off me) i'll be able to under take it. I mean hell, it lasted for a decent amount of time with a cheap budget build i had originally done. Had the output shaft not broke, i'd still be riding now. all the clutches looked good still, the over run had a little heat in them but werent worn. The low reverse drum snap ring popped off but i think that was because of the carnage the shaft explosion caused. And yes, it looked like an explosion, multiple large pieces of shaft went all over. I know most if you guys are gonna think i'm an idiot for trying it again, and maybe i am, but i think i got a bonk shaft that was brittle from being induction hardened.
+100 for iron block
+280 ish for him
50= lbsroll cage
I've had a turbo buick, but never a turbo V8 so it's possible my stroker/nitrous car and now my procharger car may not be as hard on a 4l60e as a turbo LS though.
If you are going to end up running more boost and take the car to the strip you are going to continue breaking stuff in the driveline though it's just part of it. I don't think you are an idiot, but my opinion has always been buy once cry once. I'd rather save until I can afford to put good stuff in it then continuously be working on it because I'm breaking. Of course nothing is infallible so you still can potentially break things, but you can limit that by using good stuff. Even the junk yard LS guys usually have really good stuff from the trans on back it's only the long block they cheap out on.
I havent pulled it apart yet, I have two other units on my bench i had to get done for some daily driver stuff. nothing special. I think either the input shaft exploded or the pump rotor exploded. The more I think about it, the more the rotor makes sense. When I fix it, its getting sonnax 300m shafts and a billet rotor.
i'm having thoughts. I cant deny it.
I know where an 80e is, I talked to yank and if i send my converter back they will give me credit towards an 80e stall. I have some parts I could sell out this trans. I dunno, its tempting but i want to get my car back running. cleaning it up and putting sonnax shafts in it is the easiest and cheapest and quickest option. had i had the stock shaft still in it, i dont think i'd be in this situation.
i know the headache of trans blowing. i mean shoot at least you guys got space. i dont have space in the schassis if the trans is messed up. the whole damn thing gotta come lol!
hopefully everything works out thought !!! :prayers::
ricky bobby never quit !
So I had the starter rebuilt while it was apart. The gear was torn up on the face of it so the guy grinded the damage smooth. Said there plenty more gear left to grab the flex plate. Well now its hanging up almost everytime I start it. So it sounds like some old raggedy junk. No problem, I picked up another starter. I'll built one good one myself. Put the good gear out the spare starter.
Then for the fun crap. For some reason at 5200 rpm I'm leaning out badly. Not sure why. I give it more fuel. Don't help. It's like a 15:1 afr. I immediately let out when I see it. Damnit. My duty cycle on my injectors is at 99%. Wtf. I'm thinking either the fuel pump is crapping out on me or the fuel pump is leaking at the oring in the bucket. Flock. I gotta check the fuel pressure to see what's up. I loaned out my gauge lol.
I have 60lb seimens injectors and a aeromotive 340 pump..................EDIT the leaning out was because the fuel bucket was running out of fuel when I got below half a tank fuel level. I ended up fixing it. I'll post at the end of the thread.
