My first single turbo build
Well I put the down pipe on after wrapping it just in case the wrap caused figment issues. It didn’t. I only have one plug wire I have to worry with. I can handle that. Probably put a 90 degree boot on it. Here’s what it looks like
i folded it at the end and wrapped it over itself and pyllwd it tight. It stayed while I was wrapping but I did put a tie down there.
I lije the safty wire idea much better. That will be my next purchase. Thanks truckdoug
I’m just gonna run the stock tune for now. Just kidding, I saw a guy a few days ago the put a turbo on his car and he was running the stock tune and I was just in disbelief. I have hp tuners. I don’t have much forced induction experience but I’ll figure it out. I have a wideband and I know to take it easy. I do have a buddy who’s well versed in tuning that lives up the road from me so if I need his help he will be glad to. I figure it won’t be too hard. I’ve already got the time dialed n/a and I didn’t change anything else. I’ll pull timing under load and fatten the mixture under load. I have a custom operating system I could use if I have problems using the maf but at low boost I should be ok. It’s a learning process. I was actually shopping for pistons and rods today. I plan on pulling the engine out after I get through putting an engine in my sons 4th gen ss camaro. It has a window in that block lol. Bought it that way, project car. Probably do 5.3 and single turbo on it if this project turns out well.
It’s stupid little things like this that I have to do to make my life easier in the long run, and it eats up more time. Welded the nutz in place. Yea, my first go round with them last night caused some curse words. Kept dropping those nutz. It was no fun.
What a pain in the ***! Trying finish the crossover and it’s not cooperating. No matter how many times I tried I could not get the last joining pipe close enough. I ended up with this gap. Ugh
So I made some pie cuts. I cut a few extras just in case.
Tucks good
It don’t hang any lower than the trans
Got it all tacked up. Looking good. Aaaaaand......it don’t fit. Ugh. Something must have moved on me. I got frustrated and called it a night. It was past midnight anyways. I ordered the correct flex bellows for a turbo setup from ace race parts after I came inside. I’m not gonna fight with this thing every time I take it off. And btw..... I HATE V band clamps!
