Ebay gt45
Old Nov 9, 2018 | 03:49 PM
Gav's Avatar
Gav
Default Ebay gt45
Hello,
i might get one of these but cheaper just to try for sizes
https://www.ebay.co.uk/itm/Universal...edirect=mobile
i aint shooting for more than 550 to 600 rwhp as btm end stock.
how would it perform with 66 and 1.05?? Its only £100...
my engine is ls1 5.7l 241 heads, 224r cam
regards
gav
Old Nov 9, 2018 | 04:04 PM
truckdoug's Avatar
those were the go to china cheapy for a long time. they spool kinda slow compared to other units out now. but they are cheap and very durable. it can definitely make that power level though.
Old Nov 9, 2018 | 04:24 PM
Kfxguy's Avatar
Originally Posted by Gav
Hello,
regards
gav
I'm new to this and still asking questions here and there, but what i do know is i have an on3 7875 cast wheel, journal bearing turbo on my ls1 with a tad bigger cam than you and it spools very quickly and it should easily make over 550rwhp. there was the same turbo in the for sale section for around $200 with very little use on it. Pretty good deal. I'd jump on it if I were you.
Old Nov 9, 2018 | 04:27 PM
Happy Jim's Avatar
Mwha ha ha ha - DO IT
Old Nov 10, 2018 | 05:29 AM
Gav's Avatar
Gav
Dont get too excited Jim...need to see if i can even fit a turbo in our tight engine bays...
regards
gav
Old Nov 10, 2018 | 09:39 AM
ACCLR8N's Avatar
The turbine is an excellent size for stock bottom LS. You won't get a lot of back pressure building as boost and RPM increase. Car will get better fuel economy if you care about such things. I haven't seen a larger T4 turbine. I only wish the compressor was a little bigger (75mm) and it would be perfect for my stock bottom LS2. KFXGUY is trading the larger compressor for a smaller turbine. I'm sure he sees boost quicker than I do. CarCraft did a build with a similar 7875 turbo that spiked high PSI quickly but then tapered off as RPM increased. Still, they made 1000hp with it.
Old Nov 26, 2018 | 11:34 AM
Gav's Avatar
Gav
Hi,
Got turbo now. Still need to check if fits.
its not used.
how much play should i be able to feel in the impellor shaft. I can feel a VERY slight amount of movement but not catching anything..
regards
gav
Old Nov 26, 2018 | 11:36 AM
JoeNova's Avatar
Restricted User
A little play is normal. Its a journal bearing, so the additional clearance will be taken up by pressurized oil.
Old Nov 26, 2018 | 11:38 AM
Gav's Avatar
Gav
Wow that was fast, thanks Joe. I didnt realise how heavy these things are as well...
regards
gav
Old Nov 26, 2018 | 12:06 PM
Kfxguy's Avatar
was just about to say the same thing. When I got my turbo I was alarmed by the play it had but found out that’s normal.
Old Nov 27, 2018 | 12:51 PM
BlwnLs1GTO's Avatar
regards
gav
I got two in mine. You an easily fit that turbo on either side. Passenger side is very easy it you move your battery to the trunk...
EDIT: For some reason I thought you had a GTO/Holden. Must have been kfxguys avatar that made me think that. However, there's always room for a turbo lo!
Old Nov 27, 2018 | 01:27 PM
Gav's Avatar
Gav
This is my eng bay...
https://ls1tech.com/forums/forced-in...urbo-here.html
regards
gav
Old Dec 20, 2018 | 11:28 AM
Gav's Avatar
Gav
Hi,
just a question, is there anything stopping me mounting the turbo hot side vertical so that the divided t4 flange is vertical and the two banks come in from the side?
dont see any pictures of this but if the oil inlet outlet is still top and bottom then is there a problem doing it this way?
regards
gav
Old Dec 20, 2018 | 11:45 AM
JoeNova's Avatar
Restricted User
Hi,
regards
gav
The only thing that determines mounting is the feed/drain.
Old Dec 20, 2018 | 03:07 PM
Gav's Avatar
Gav
Cheers Joe, and i guess the feed drain can be orientated 360?
regards
gav
Old Dec 20, 2018 | 03:24 PM
01ssreda4's Avatar
feed at 12 oclock, drain at 6.
Old Apr 18, 2020 | 12:47 PM
Gav's Avatar
Gav
With time on my hands thought i would try fitting this in...god its tight....any ideas? I would need a very small air filter and god knows where to fit wastegate...
Old Apr 18, 2020 | 12:53 PM
Gav's Avatar
Gav
Was planning on 1.5sch 10 elbows to 2" sch 10 log to inlet of turbo then 4"dp to twin 3" sidepipes.
then 3" cold side to an intercooler, cant fit the normal 31" wide one in, would have to be smaller...
regards
gav
Old Apr 19, 2020 | 11:37 AM
Gav's Avatar
Gav
More checks today.
gonna fit it where i pinned it if i can.
Old May 20, 2020 | 03:46 PM
Gav's Avatar
Gav
Bit more done...
2" sch10 elbows to t4
