Turbo 5.3 Ford Focus
As of today most of my parts have arived to get it running. My plan is to get it running na this week then dyno just to make sure this junk yard motor is healthy.
My headers i built work flipped around.
gonna run on a stock motor boosted while i build a motor
Turbo is a Garett GTX 42 with Tial stainless turbine housing
running holley hp system
edelbrock intake
Non intercooled e85.
link to my original build https://ls1tech.com/forums/conversio...ord-focus.html
turbo is a little on the small side but I already had it.
runs great. Has a little blue smoke when you rev it. probably needs valve seals
Compression ratio was perfect.
Gonna dyno next week just to see.
check out my original build thread when you get a chance. It shows my progress from small block Chevy and then 4 ls motors. It’s been quite the journey. Excited about the boost though.
I will post more pics later
No Salvage yards in the area? Normally you get to hear them run, yard drive, compression test, etc before they drop them out. Doesn't catch every problem but sure beats picking up someone elses previously enjoyed failure.
https://www.carparts.com/
I got an aluminum 5.3 today.
I am gonna start working on mocking up everything this week,
I bought a radiator for a jeep cherokee and it fits perfect tucked up behind the bumber. gives me more room for the turbo. Plus it is actually larger than my old radiator which was for a bmw
gonna fab up everthing then swap in the good motor.
Anyway I pulled the heads off and cleaned out the engine. Had minor surface rust that washed off with oil. Gonna use this as an opportunity to add studs.
Also got some more fab work done. Made the collector.
