Summit Racing Intercoolers
Old Feb 1, 2020 | 09:31 AM
SE-R Spec's Avatar
Default Summit Racing Intercoolers
Has anyone had any experience with summit racing’s intercoolers?
Planning for 700hp on a VS Racing 80mm and 6.0 combo and was looking for an 800+ hp rated intercooler.
Treadstone’s TR1045 is rated for 860hp and has the exact same measurements as this summit unit
https://www.summitracing.com/parts/sum-260005/
Treadstone also guarantees losing less than 2 psi with a 1300 cfm flow rate but there isn’t much info like this for the summit cooler.
Derek
Old Feb 1, 2020 | 02:01 PM
stevieturbo's Avatar
On appearances alone, the Treadstone looks the better unit. Mainly as the Summit just has those same tiny end tanks every Chinese unit uses.
Although ultimately the core itself is what matters, and neither show images or give any detail on that aspect.
Old Feb 1, 2020 | 05:46 PM
truckdoug's Avatar
if thats not the run of the mill chinese ebay $150 intercooler i'll eat a tin can
Old Feb 1, 2020 | 08:50 PM
SE-R Spec's Avatar
I nabbed a Mishimoto R-line intercooler for $250 today. Same specs as TR1045. I’ve also had good a experience with mishi prior to this, I ran one of their radiators on an SR20 240sx I built with no fan and it never overheated even in the summer. Some will be skeptical but that’s what happened.
Ill do a build thread and update the R-lines efficiency in there.
Derek
Old Feb 1, 2020 | 10:48 PM
truckdoug's Avatar
i believe that. sr20 is basically a forklift motor and those are really good at running with no radiator at all haha
Old Feb 2, 2020 | 04:24 AM
Really, Summit should be stepping up. The size of their business etc, they should be able to offer quality product with good cores at keen prices. Maybe they are not basic Chinese stuff, but as they offer no information at all or images etc of the actual core....we can only assume they are cheap stuff.
Old Feb 2, 2020 | 09:52 AM
truckdoug's Avatar
those end tanks, that plate design? ****, the photo looks like stock ad copy from the ebay ads!
i mean I have taken that POS a2a to 1000 wheel, but I aint paying no 300 dollhairs for it!
Old Feb 2, 2020 | 12:09 PM
ddnspider's Avatar
They're a vendor on here.... @Summitracing can you share details?
Old Feb 2, 2020 | 12:39 PM
truckdoug's Avatar
jeez callin em out is kinda harsh bro, aint like the tech rep for our little forum sets the prices
Old Feb 2, 2020 | 12:44 PM
ddnspider's Avatar
Uh, you bashed them about their quality and was going to eat a tin can without them even being able to confirm or deny the truth lol.
Old Feb 2, 2020 | 12:56 PM
And maybe the core they use isnt the same chinese **** many love ?
If it is something better, it makes sense for them to advertise the fact and give that information to customers.
Old Feb 3, 2020 | 01:38 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Fit the biggest intercooler you can, and spend money somewhere else. Heat exchanger technology is pretty damn simple, and the chinese figured out how to copy the good ones a long time ago. Brand names in this area mean about as much in function as they do with women's purses. Your dollars could equal more horsepower in almost any other area of a build.
Old Feb 3, 2020 | 06:17 AM
yenkomike's Avatar
i have the mishimoto unit on my nova so far it has been great. looks much better than the ebay/ on3 coolers ive seen. no track runs yet but the car has made 705 hp to the wheels on 14 psi boost. temp diddnt rise much but a 4 or 5 sec dyno pull is a short test. no issue with flow.
Old Feb 3, 2020 | 08:48 AM
AwesomeAuto's Avatar
Summit isn't a manufacturer. They're a distributor.
Is it likely the same intercooler as the cheap stuff? Maybe.
You have to determine who is better to buy from. An ebay company that refuses your return, or Summit which will gladly take returns and answer questions.
Some of that extra cost is customer service.
Old Feb 3, 2020 | 09:30 AM
SLOW SEDAN's Avatar
Or no intercooler, lots of people here running E85 and fairly low boost on the street. At 14PSI or so my IAT's don't get any warmer then the average LSA build's I've logged and I have faster spool then having a bunch of piping and a big front mount, even up to 20PSI they don't get all that crazy. Lots of guys have run 9's, 8's or even faster without an intercooler at all. Really I think IAT's are overblown in all but the most stressed applications since E85, methanol and other fuels seem to thrive in a wide range of conditions. I've run pump gas and meth injection with no intercooler up to some pretty high decent levels and it performed well too.
Old Feb 3, 2020 | 09:32 AM
SLOW SEDAN's Avatar
They started carrying a lot of Chinese stuff recently, VS turbos and the like, I wouldn't be shocked they did the same for intercoolers. I agree they should chime in, especially if they have any data from testing.
SE-R Spec's Avatar
thank you for the input!
Old Feb 3, 2020 | 11:07 AM
Summitracing's Avatar
LS1Tech Sponsor
Thanks for the tag ddnspider. We haven't tested these. We would be happy to get pictures of the core if that is something the community needs.
__________________
800-230-3030
www.SummitRacing.com
Old Feb 3, 2020 | 12:12 PM
You really cannot have such a poor grasp of what intercoolers do, or their construction ? That seems hard to believe....but you're shouting it out very loud.
Old Feb 3, 2020 | 12:23 PM
Who you would expect would communicate with the manufacturers of those products, to ensure they are suitable and of good quality to be sold from their stores.
They are still cheap affordable units, but it would still be nice to see some core details, in case there maybe is something to set them above what others are selling. On a low power, low airflow car, these will undoubtedly work very well, simply as they will be oversized for the application. But on bigger motors, needing more air, and maybe having high temps to deal with....of course quality matters.
I posted this before on the forum, and it's a good back to back test worth posting again.
RH went from what already appears to be a pretty good intercooler to something a little bigger, and there was quite a difference in performance. So for anyone to say any cheap crap IC will work as well as a good unit, they're just nuts..
It would be nice to see a comparison like this test, but also with the horizontal cores too, and with various brands.
Potential improvements of IAT are one thing, but airflow is another. For those chiming about temps, ideally they'd need to hold a load for maybe 15-20s to get an accurate temperature reading once stabilised, as most typical air temp sensors are pretty slow, even though many will claim "fast acting".
So those low readings in a lot of cases will simply be false as they simply havent caught up yet with the actual temperature.
