Meth injection after throttle body
My thoughts are... use small reservoir, pump, relay, pressure switch, back check valve, nozzle, and nozzle holder plus the necessary line. Simple on/off system with a very small nozzle like a 3 gph to start with on at 4 psi. Primary fuel will remain 50% ethanol. This is on a 377 with 10.6 to 1 compression with cathedral port top end and about 20 psi via over spun D1x procharger with large procharger air to air.
Thoughts are start super small and early injection then maybe add another small nozzle pre-iat sensor later. This lets me get some benefit of the water/meth without relying heavily upon it since I'm running 50% ethanol as a primary fuel.
I know there are some serious meth users here that can give me some solid input on this...
I think you'll have to use way more than a 3gph nozzle to start seeing it give you anymore tune to play with though, if that's what you're ultimately going after. I think at 20psi I would just go straight to a duel nozzle setup with at least 15gph of nozzle.
There are a couple calculators you can use and some charts to gauge the nozzle size you need but I made a guess at at 800hp at 20psi for your setup and that would use 15gph worth of nozzle...so two nozzles. I run a 10gph+5gph on a 5.3 with 9.3:1 at 22psi and its not enough, I need to make the 5gph another 10gph because I can't get past 6* of timing. But I'm on pure petroleum 90octane because we grow frost and snow here instead of corn.
Start with more nozzle, a lot more. If you go to the track, the reservoir has to be <1gal, but with that in mind, get the most reservoir you can fit because it sucks it down with high HP spray amounts.
The next step if I like that would be a bigger nozzle, then possibly adding a second nozzle before the IAT as well. Just want to see how it goes first with the single small nozzle.
You could drill and tap that new Weiand intake I bet
With a catch can you control vacuum and boost from the intake ports behind the TB with a one way check valve. But those valves control air pressure, not liquid.
How big of a nozzle could someone possibly run with a 4 psi turn on point with a simple off on pressure switch/relay setup without having issues? Also how much needs to be sprayed with a 50/50 mix to even be worth my time? Not so much using it for max effect, but to even be enough to be worth doing?
Also, why not just run more ethanol as your primary fuel and not worry about the meth at all? I've ran IATs at 300 degrees before on E85 with a fair bit of boost and never experienced any issues with detonation.
Im currently running 1200 cc/min injectors and a 4303 pump with 58 psi base pressure. Hitting 90 percent duty cycle at 7200 rpm at 20 psi with 50 percent ethanol.
My blower is already over spun and no planning to add more power at this time. I have no issues with IAT and have ran as high as 18 degrees peak timing with plugs showing I could probably add another degree safely.
Long term I do want more power. My thoughts are to learn a little about meth injection while I don’t actually need it and see how much I like it. I’d like to be in the 1200 plus club someday still with a Procharger and the fuel delivery gets pretty crazy with ethanol in a street car at those levels. Ive considered a second 4303 or a brushless aeromotive with speed control aa well.
Just trying to learn as I do all my own work and tuning, but this car is making more power than I’ve ever personally owned so 1200 rwhp will definitely be uncharted territory for me.
I did run a nitrous plate spraying 150 shot on a 408 way back in 2006-2008. It worked well and I liked nitrous, but will never go back to it.
Nitrous gets sprayed in at 900 PSI and turns to gas at -127*F. It evaporates and disperses almost instantly coming out of the nozzle.
Methanol typically gets injected at ~60-100 PSI (Pump ratings do NOT equal nozzle pressure) and turns to gas at 148.5*F, a 275.5*F difference from Nitrous. This is worse when mixed with heavier, harder to boil water.
Atomization and distribution between the two are like comparing apples to tractors.
Spraying meth 12-18" before the throttle body helps make sure that the distribution is roughly the same as the air distribution for each cylinder, so cylinders that get less air also get less meth, and the ones that get more air get more meth, helping with overall uniformity.
