Front mounted A2W or intake mounted A2W
Found the thread https://ls1tech.com/forums/forced-in...oler-data.html
The stack setup holds no appeal for me, I already have a 4" cowl hood and I don't want to cut o hole in it.
The nose mount setups vary, Ray's Sweet Pea setup is not huge and he said he works pretty good. Obviously the issue for any of us is mounting the a/w cooler and not having it adversely affecting cooling.
My boost is still low in the 12-14 lb. range but it seems to work quite well even with just ambient temp water, logging IAT's never get above 100 degrees even on a hot day, can't wait to throw some ice in it and see how cold it can get.
Initially I thought you'd have to keep ice in it all the time in order for it to work but water is so much more efficient at pulling heat out of the aluminum than air that even ambient water works really well.
Now I'd imagine that will change when you start to turn the boost up and dependent upon turbo efficiency but with my S484 I don't think I'll run into that problem until I really lean on it.
I ended up going to one a bit bigger than that one and it works laughably well. Mine is a CSF core made by Tin Soldier Racecars, I believe they rate it at 2500hp. In 90* ambient my IAT's don't rise over 85 without the IC pump even being on, with ice and pump it'll be down at 60*.
The 2nd solution kind of interests me, what where the IATs like?
The second solution would get to 130-140 but I didn't use ice on that setup when I had it. I built another kit recently for a friend with the same core, on the dyno after repeated pulls it got to about the same as what I saw with it. However, we did a single pull with fresh ice it was closer to 90-100* through the pull. Granted that was only a single gear at the ~900whp level with a typical trunk tank and EWP150 pump feeding it. Location wise was not the best in either of the installs because they were both behind the radiator getting blasted with hot air. Still plenty safe IAT's to me if you don't have room for a behemoth.
Your review of the second solution is pretty interesting. That's about the only setup I could fit in my '67, the Dangler setup would require I run a offset radiator at a minimum, and I'd have to make compromises that would make mine less of a street car.
