Projected horsepower
Old Nov 6, 2023 | 06:57 PM
  #161
Tommy42088's Avatar
I'm really hoping to make that tune appointment this weekend, I'm gonna change the plugs again tomorrow just in case. I have them gapped at 25 but was thinking close the gap a little and hopefully get this sputter out with the tune, if it doesn't over heat that is
Old Nov 6, 2023 | 07:06 PM
  #162
GMCGreg's Avatar
.025 plug gap is working fine for me at 16lbs with stock coils . Hole in Stat helps with filling and allows a bit of flow around the Stat for earlier opening and stable temps
Old Nov 6, 2023 | 07:12 PM
  #163
Tommy42088's Avatar
I'll leave the gap at 25 then, if anything I'll have a spare set while it's being tuned if need be and I'll definitely consider drilling the hole. Only thing is if its not over heating anymore i might not want to mess with it
Old Nov 6, 2023 | 07:24 PM
  #164
GMCGreg's Avatar
I agree if it's working now , leave it , tune it and drill a hole another time when you have time or coolant has been drained for any reason. Good luck
Old Nov 6, 2023 | 07:29 PM
  #165
Tommy42088's Avatar
most definitely, I'll update how the tune goes
Old Nov 6, 2023 | 07:51 PM
  #166
ddnspider's Avatar
The hole in the stat is because in some instances you can get an air pocket on the back side of the thermostat. It'll keep the stay from opening regardless of what happens. The small hole allows the air to bleed through the hole and let the thermostat see the temperature so it can open. Curious how it goes when you fill it back up and swap the cap. If it still overheats its worth doing a pressure test on the cooling system.
Old Nov 6, 2023 | 11:37 PM
  #167
Dian's Avatar
frankly i didt read all of this, but:
https://www.lislecorp.com/specialty-...-leak-detector
or go to a place that can do this. pretty sure the gasket is gone.
or check if you can feel a fast pressure buil up i the upper rad hose, after starting the car cold and reving engine a bit. squeeze hose, rad full, cap on. i woulndt rely on it.
Old Nov 7, 2023 | 05:11 AM
  #168
Tommy42088's Avatar
that's interesting, about what size bit do you usually drill the hole with? I'll update you this afternoon when I get home from work. I have to pick up some coolant then I'll give it a try. It did seem like air though after I messed with it for a while tho so I'm hopeful of that.
Old Nov 7, 2023 | 05:15 AM
  #169
Tommy42088's Avatar
I don't think it's the gaskets, it calmed down quit a bit after a let it run for a while. To the put when I could watch the inside of the funnel and see the water flowing from left to right inside the upper hose where the radiator supply is
Old Nov 7, 2023 | 05:42 AM
  #170
ddnspider's Avatar
If you finally got it to burp i woulsnt touch it until you confirm if it overheats or not. Drill bit was something really small like a 1/32".
Old Nov 7, 2023 | 05:44 AM
  #171
Tommy42088's Avatar
most definitely, ill find out tonight.
Old Nov 7, 2023 | 06:39 AM
  #172
GMCGreg's Avatar
mine is 1/8 "
Old Nov 7, 2023 | 09:26 AM
  #173
GMCGreg's Avatar
Oh and clock that hole at or near 12 o'clock - better for bleeding/ passing air
Old Nov 7, 2023 | 09:46 AM
  #174
Tommy42088's Avatar
10-4 will do, thanks for the advice man. Yall have been alot of help
Old Nov 7, 2023 | 10:22 AM
  #175
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Some of my buddies would drill a few holes, their primary concern was getting all the air out.
I don't run heat or a thermo stat, I run this.
Old Nov 7, 2023 | 11:54 AM
  #176
Tommy42088's Avatar
wow that's interesting, my only concern would be losing my heater if i went to big of a hole
Old Nov 7, 2023 | 01:23 PM
  #177
LS1Tech Co-Founder
If you are running heat I think you'd want a thermostat. I wouldn't be shy about drilling more than one hole to help the system bleed, I think my buddies been drilling 4-5.
Old Nov 7, 2023 | 03:20 PM
  #178
Tommy42088's Avatar
most definitely run heat, I drive this truck on the street pretty often. Well I did b4 I started this nightmare of a turbo setup. Hopefully I'm finally getting it together
Old Nov 7, 2023 | 06:05 PM
  #179
Tommy42088's Avatar
Didn't run hot!!! Didn't even bubble gurgle any. Plugs will be here Thursday then off to tune
Old Nov 9, 2023 | 07:08 AM
  #180
Tommy42088's Avatar
I pulled the plugs yesterday, they weren't perfect but none if them looked bad enough to cause a hesitation. #4 was probably the worse. I also read some interesting articles on hp tuners last night with guys having similar problems and alot of them were tuning issues, Saturday we will get it hooked up to hp tuners and I'm curious to see if it's tune related or I possibly have a bad coil or something in the nature
