Projected horsepower
Old Nov 6, 2023 | 05:28 AM
  #141
Tommy42088's Avatar
[QUOTE=ddnspider;20527984]You're saying you've driven the truck since the gasket change with no overheating and haven't been WOT with the turbo setup? If so that would be a good sign.[/QUOTE
yes that is correct
Old Nov 6, 2023 | 07:32 AM
  #142
ddnspider's Avatar
It's very curious for it to smoke out the radiator like that. What's your fan setup and what thermostat?
Old Nov 6, 2023 | 08:56 AM
  #143
Tommy42088's Avatar
I'm not sure on the fans, it seems around 200 they come on , but I'm not sure on the exact number. I tried a 185 & 165 to see if I noticed any difference. I tested them in boiling water and they both came open like they should. I did notice if I drive the truck the temperature seems to go down, it's when I slow down or idle the truck it starts to go up and when I kill it I can hear it boiling and when I pop the hood the coolants it's overflowing from reservoir. Almost like it just boils it all out. Definitely pressure on the cap when I ease it open. I flushed the radiator yesterday and the water Is immediately dirty as hell, not like a oil color or anything like that, more like rust
Old Nov 6, 2023 | 09:29 AM
  #144
ddnspider's Avatar
Are they stock fans? I typically turn them both on at 185. I'm wondering if you have a bad radiator cap. It would be cheap to replace. The cap will be under pressure when the truck is hot.
Old Nov 6, 2023 | 09:54 AM
  #145
Tommy42088's Avatar
no, I have it converted to dual fans on a Nelson harness. I'll definitely put another radiator cap on it just to give it a try. The only problem I have with that is when I crank the truck with no cap on it and the upside down bottle on it then why is it steaming like that. The cap hasn't even been used at the point. When I bled my wife's car I could let it run without the cap and nothing overflowed and there wasn't pressure. This truck you gotta stay back a few feet or it will spray you with hot water. I was hoping thermostat but I put it in boiling water and it opened
Old Nov 6, 2023 | 11:15 AM
  #146
ddnspider's Avatar
That's exactly why gametech and I were wondering about a blown head gasket.
Old Nov 6, 2023 | 11:29 AM
  #147
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
In my distant past when I had a bad head gasket, I could smell the coolant in the tail pipes.
At this point I'd source another cap, I run a Moroso 19-21 but maybe some of the guys on here have stronger opinion on your options... Stant for example.
I'd also make sure both fans are coming on. If you are Holley Terminator it would read off the coolant temp sensor on the driver's side front cylinder head. I'd have both fans come on. I'd make sure they are also pulling.
If you are Holley and want to partner up with a tuner who is great at trouble shooting, I'd suggest Andrew who has the '67 Cougar build on here. He just figured out why a local buddy's swap was running poorly.
Old Nov 6, 2023 | 12:04 PM
  #148
Tommy42088's Avatar
I understand the cap thing but that can't be the issue because it's steaming before I ever put the cap on and Im not on holley, i guess as some point ill make the transition but im not just not there yet, and both my fans are definitely coming on, i watched them come on yesterday and ok but is he local to me? When we had it on hp tuners over the weekend we watched the temp go up so it's definitely rising. We instantly shut it down tho. It has never reached excessive temps that would cause the head gaskets to blow, how would they blow so easily if I've never WOT or overheated to the extreme?
Old Nov 6, 2023 | 12:17 PM
  #149
Tommy42088's Avatar
I could be wrong but I feel like it's clogged somewhere, with the water being rusty like it is I feel like that's maybe causing a build up somewhere, could I be correct?
Old Nov 6, 2023 | 12:57 PM
  #150
ddnspider's Avatar
Pull the water pump and empty the rad again. Also check the fan airflow direction.
Old Nov 6, 2023 | 01:04 PM
  #151
Tommy42088's Avatar
I've changed the waterpump twice I'd say within the last 2 years, the last time I did just whenever got the heads port n polished and i noiticed rust so i changed it again. It was under warranty. So honestly its been rusty, just hasn't caused this problem. I literally flushed the radiator yesterday and then in about 5 minutes with fresh coolant it was back rusty again that quick
Old Nov 6, 2023 | 01:57 PM
  #152
Quito195's Avatar
Didn’t this truck get driven on the dyno for like a month? Where was the over heating problem then?
Old Nov 6, 2023 | 02:00 PM
  #153
Tommy42088's Avatar
he wasn't able to make any WOT pulls, it was burning spark plug wires at the time so we couldnt get a full rev out of it, and i called him yesterday and asked him about it and he said it didn't over heat any on him. Forgranted it was a little colder at the tike and the dyno fans were also on it
Old Nov 6, 2023 | 04:45 PM
  #154
Tommy42088's Avatar
My lower radiator hose seems to be staying cold and I definitely don't feel much pressure on it, should it be that way?
Old Nov 6, 2023 | 04:50 PM
  #155
Project GatTagO's Avatar
Sounds like you have air in the system and the thermostat isn't opening.
Andrew
Old Nov 6, 2023 | 04:55 PM
  #156
Tommy42088's Avatar
Andrew
I checked it yesterday it hot water and it opened but i guess i shoulf of checked the water temperature to verify when it was opening
Old Nov 6, 2023 | 05:01 PM
  #157
I'm not saying the thermostat is bad. Did you fill the engine through the upper radiator hose?
Andrew
Old Nov 6, 2023 | 05:29 PM
  #158
ddnspider's Avatar
Always backfill the motor through the top hose. I typically drill a small hole in the thermostat too.
Old Nov 6, 2023 | 06:43 PM
  #159
GMCGreg's Avatar
As you said testing a 160 stat in boiling water is not exactly accurate but does prove it isn't siezed shut. Hole drilled in Stat body is definitely a good idea - always do that. Your problem certainly seems like a flow issue , yrs ago I saw a gm pump where the plastic impeller was cracked and pretty much free wheeling on the shaft , was a bit of head scratching on that one . Not sure what an ls truck pump loo,s like inside but thought I would mention it . Can you disconnect the steam line at the rad or reservoir while running? That would establish that coolant is flowing at least. Top hose / hot side tank getting hot? Could have the coolant tested for combustion products . Do you have a rad pressure tester ? Can hook that up while running and if there's a quick rise in pressure then you have head gasket issues or a crack.
Old Nov 6, 2023 | 06:48 PM
  #160
Tommy42088's Avatar
I just bled the **** out of it again and it bubbled its *** off for quite a while, seemed to calm down a bit after about 45 minutes. Then once I killed it I heard all the water suck down into the motor so hopefully I'm ok, I'll top it off tomorrow once it cools, what's the purpose of drilling the hole? I've never heard of anyone doing that? Wouldn't that kind of defeat the purpose of a thermostat?
