Projected horsepower
nvm I see what it is, I'm going buy one now
So overheating, that can be a few things. You can make sure you got all the air out of the system. I've had luck jacking up the front of the vehicle making the rad cap the highest point. Used a universal fill/cap deal with it's funnel, put in about 2 points, could immediately see air bubbles. Not sure how much I put in there, but after 24 hours I got all the air out.
The second issue is tune. I'll defer to the tuners like Andrew but generally we end up running more idle and cruise timing than an NA combo.
Ive tried this over n over, it just steams and blow the water like this and then begins to over heat again
This one seems to fluctuate so maybe im on to something
On the IR gun, those things can be tempermental. Make sure youre exactly rhe same spot on the primary and even then youll see temp swings because of header designs. As long as youre seeijg a few hundred degrees on all 8 theyre all firing.
could it be my radiator? Everything is new but that, the water does get dirty pretty quickly inside so Maybe its stopped up?
