Projected horsepower
Old Nov 2, 2023 | 12:02 PM
  #101
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You're definitely headed in the right direction now.
I'm a couple years running truck manifolds.
Old Nov 3, 2023 | 12:32 AM
  #102
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by Tommy42088
So I got it all together last night and took it for a spin, I did notice the hesitation but I don't see the plugs arcing or anything like that. I checked at night and all that seems ok. I did notice my check engine light was now on and which it wasn't before and it pulled PO122 & PO103. So tonight I'll check the voltage on the tps sensor and make sure it hasn't gone bad on me and the maf code is a bit confusing when the truck is tuned on speed density. I'm also going to take an air compressor and put a little air into my hobbs switch and make sure my second fuel pump is coming on.
The MAF code is necessary in order to fail back to speed density, but he should not have left it turning on the MIL light. He has a couple of other MAF codes set to no mil light, but not that one. Unless the tune has been changed since the one you posted. In that case, the TPS code would set the MIL light anyway.
Old Nov 3, 2023 | 05:09 AM
  #103
Tommy42088's Avatar
no I haven't gotten it retune yet and ok that makes sense for the maf code but why the tps? So do i need to change the tps sensor or is that just tune related as well??
Old Nov 3, 2023 | 05:42 AM
  #104
ddnspider's Avatar
actually it's not. Simply setting the rpm threshold for airflow Calc to a very low rpm will set the vehicle to MAF only while running. You don't need to trip a MIL.
Old Nov 3, 2023 | 05:44 AM
  #105
Tommy42088's Avatar
what about the tps sensor? Should I change it or it that tune related
Old Nov 3, 2023 | 09:28 AM
  #106
ddnspider's Avatar
I didn't see what TB youre using. If its stock then the sensor is probably bad. If its not stock then it could either be sensor or tune.
Old Nov 3, 2023 | 09:34 AM
  #107
Tommy42088's Avatar
102mm and the sensor was fine before. I didn't have a check engine light at all before. Unless it possible went bad in that time frame.
Old Nov 3, 2023 | 09:41 AM
  #108
ddnspider's Avatar
Seems unlikely it just died in that window. I guess it's possible. It may be worth swapping sensors to verify, but it is possible that the tune is the culprit now that other issues are being sorted out.
Old Nov 3, 2023 | 09:54 AM
  #109
Tommy42088's Avatar
I'll check it tonight with a meter and see if everything is reading OK on it. Seems unlikely to me as well but ill check. Never imagined I'd be working all these bugs out my truck. It ran excellent b4
Old Nov 3, 2023 | 10:00 AM
  #110
ddnspider's Avatar
Such is the boosted life lol. Once you sort all of the bugs out it'll totally be worth it. Some of your issues were self inflicted but that's pretty typical lol.
Old Nov 3, 2023 | 11:42 AM
  #111
Tommy42088's Avatar
yeh I took it for a spin last night, it definitely feels like it wants to pull, i didnt want to go WOT tho, not until im sure everything is right and yes i know. I guarantee you one thing though, I'm a quick learner and I definitely learned alot from this. First mistake is on me, as long as I don't do it twice. I need to verify the tps sensor is working and I had added that second pump and I hadn't verified that it's working so I'm gonna put a little air into the hobbs switch and check it and pull some reading on the tps tonight.
Old Nov 3, 2023 | 03:38 PM
  #112
LS1Tech Co-Founder
Yeah the only way to work all the bugs out is to drive it, but you'll get it. I can drive my car 90 minutes no problems.
I do carry some tools, spare items lol.
Old Nov 3, 2023 | 04:09 PM
  #113
Tommy42088's Avatar
I most definitely keep a few wrenches behind the seat, i drove mine 11 hours last year when it was still setup for nitrous but i didn't have any issues. That's why I say I know the truck runs good, I just have to get out the bugs worked out from putting the turbo on it.
Old Nov 4, 2023 | 12:48 AM
  #114
gametech's Avatar
You are thinking backwards. He is SD only, not MAF only. This means the MAF has to be failed. The code has to be set, but his tuner should have unchecked MIL light for it.
Old Nov 4, 2023 | 07:35 AM
  #115
ddnspider's Avatar
ah I thought he was running MAF only, nvmd then!
Old Nov 4, 2023 | 10:11 AM
  #116
Tommy42088's Avatar
I'll definitely mention that when I get it tuned again, and I put a meter on the tps sensor last night and got my plus 5v and when I checked the other wite the voltage went up and down when I rolled the throttle up and it down the voltage went up and down and ground was good as well.
Old Nov 5, 2023 | 12:04 PM
  #117
Tommy42088's Avatar
Ready to blow this damn thing up, it's hesitating all the way down the road and now even running hot, water overflowing out the reservoir. This thing is giving me hell man. I pulled the plugs and the look good, checked fuel pressure
Old Nov 5, 2023 | 12:12 PM
  #118
TrendSetter's Avatar
if it was easy everyone would do it. keep at it.
overheating might just be a big air bubble in the system.
Old Nov 5, 2023 | 01:55 PM
  #119
ddnspider's Avatar
You need to log the truck when driving. Get the front end in the air and put an Lisle radiator overflow on it and let it idle for awhile with the heat on and try to burp the system. Get an IR gun on the header primaries if you can and make sure it's firing on all 8. Many simple things and you may have a tune issue or multiple things going on.
Old Nov 5, 2023 | 02:53 PM
  #120
Tommy42088's Avatar
I just flushed my radiator and going to try and bleed it again, although Ive done this already a few times
it bubbles its alot out the cap, i put a bottle upside down with the bottom cut out and let it run like that but it seems like it continues to bubble, brand new head gaskets, water pump maybe 2 months old and thermostat is good, I checked it in boiling water
