Projected horsepower
I'm gaining the same experience with my current project, learning where all the wiring goes, removing some, adding others.
But it's all good because I'm getting to know the car better and better.
I looked it up and apparently Delphi, Eaton, and Johnson all have produced these lifters for mellings and they had slight differences like the single or dual grooves. It also says there were no critical differences that would affect performance or usability if they are used together.
Edit- but like you just did time is a factor at times too. Alot faster to go to the parts store vs waiting from a dealer or online
https://youtu.be/5f4ULhba7AU?si=S6A_FZXDr66X_MnV
He got the info straight from Delphi.
My only other thought would be that perhaps the original LS7 lifter went through a more rigorous QC standard since those engines were hand built.
Might the same difference be in the lifters mentioned is that some have better quality standards then others?
So I went on Rock Auto and looked up the PN for the 2009 LS7 lifter, then looked up 2005 5.3 lifter, same PN.
I bet they call them LS7 lifters as a marketing ploy which makes sense.
