Rolling 2-Step Stops Working Over 25mph?
Old May 20, 2024 | 10:25 AM
Black_Sunshine_99's Avatar
Default Rolling 2-Step Stops Working Over 25mph?
Good morning gents,
Got kind of a weird one here, I wired up my MSD 2-Step on a rocker switch so I can select either the Trans-brake or my brake pedal as an activation input.
On the brake pedal the idea was to have a rolling 2-step for building boost for roll racing or rolling burnouts.
It works really, really well and will build about 4-5 lbs. of boost in first gear up to about 20-25mph but above that it doesn't seem to work which is a bummer because ideally, I'd like it to work up to at least 40-45 mph.
Is there any reason you guys can think of that the 2-step would only work at 25mph and slower?
Old May 20, 2024 | 10:35 AM
TrendSetter's Avatar
the msd 2 step will lock itself out if you activate it with the engine above a certain rpm
check out the second note on the first page: https://documents.holley.com/8733.pdf
Old May 20, 2024 | 10:51 AM
Ah okay, I think I understand, and I do have it set at 3,000 rpm for now.
So, I have to activate it at 2,000 rpm or less and then boost my way up to 40 mph I'm guessing and then hold it there?
Or raise my 2-step higher in the RPM range to get closer to 40 mph?
Old May 20, 2024 | 11:04 AM
when i had one on my s10 it was a stick car so i just pushed the clutch in to let the engine rpm drop down enough to activate it then floored it and did my rolling fireballs
Old May 20, 2024 | 12:01 PM
I've got a manual valve body TH400 in the car so I can't down shift, so I have to plan these types of hits anyways.
I think I'll try raising the rpm up since it's easy to do and see if I can get it closer to the 40mph target and if anything, it'll just make it easier at lower speeds.
Thank you for the help my friend, I would have never thought the answer would be in the MSD instructions lol.
Old May 22, 2024 | 09:18 AM
@TrendSetter how did you make fireballs shoot out of the exhaust?
I need this in my life lol.
Old May 22, 2024 | 09:27 AM
efilive custom os5 has nitrous control which gives you timing and fuel modifiers with a wired input.
i set it up so on the 2 step it added a bunch of fuel and pulled a bunch of timing. run the exhaust out the front bumper and there ya go
Old May 22, 2024 | 09:36 AM
Oh okay, bummer, I'm still on the factory PCM.
Old May 22, 2024 | 09:52 AM
yeah thats what i was on. an 0411.
Old May 22, 2024 | 02:47 PM
Oh, I misread that and was thinking an aftermarket system for some reason.
I'm using HP Tuners, is there something I do can with that?
The rolling two step is killer and if I could make it spit fireballs that would be icing on the cake lol.
